Home > General (L405) > 2013 l405 5.0 L Supercharged with high milage
Hammer
Australia 2007 Range Rover Vogue TDV8 Zambezi Silver
Hi Guys, I’m looking at a supercharged with 200,000 kms, anything to watch out for? Been doing some research tonight but could not find much except mention of timing chains.
I own a p38 with 200,000ks love it for off-road and a 2007 vogue 3.6 with 300,000 which has been a great car.
Not sure what type of high milage can be expected from a 5.0l supercharged
Cheers Paul 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
2000 P38, Gen3s, 2 inch lift, KM2s 285/75/16
Post #562427 23rd Jul 2020 2:44pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Paul
I am not an expert in high mileages however I reckon as long as it has been serviced correctly it should be fine, over here it's the rust that kills them before the engine, maintenance is the issue, Thumbs Up
Post #562430 23rd Jul 2020 4:05pm
WB
The timing chain Tensioners and guides are an issue and its an expensive job so check if that’s been done.
There aren’t a lot of us with older petrol models on this forum - worth checking on the US forums where they’re more common.
Post #562431 23rd Jul 2020 4:18pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
120k Miles isn't really high mileage.
If it has been looked after you will probably find it has had alot of the common faults replaced and have a new lease of life.
Post #562462 23rd Jul 2020 9:39pm
Hammer
Thank you all for your replies
Any idea the cost of parts for timing chain job? I do all my maintenance myself, and order parts from UK,
thanks again Paul 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #562466 23rd Jul 2020 10:08pm
WB
The parts including tensioners, guides, chains, all the gaskets, water pump (good idea to replace while its apart if it hasn’t been done), accessory and supercharger belts are about £900. Its a good idea to change the supercharger isolator and pulley bearing and change the supercharger oil while it’s apart too - about £200 in parts.
If you can get as much of the specific history as possible. The differential(s), transfer case and gearbox oil should all be done around 100k miles or 10 years and the gearbox filter/sump also.
Also test drive it for clunks or ride issues from the suspension. Take a good look underneath for leaking shock absorbers too.
Post #562467 23rd Jul 2020 10:16pm
Hammer
Thank you WB 2015 AB 5.0 Supercharged
2007 TDV8 Vogue
Post #562468 23rd Jul 2020 10:20pm
johnf
2013 Range Rover Autobiography 5.0 SC V8 Bonatti Grey
I'm up to 137,000 miles (220,000km) in my 2013 supercharged and have only had one serious blip at about 95,000 miles - needed a new hydraulic tensioner and shortly afterwards a new fuel injector - total cost just over £5,000 of which Landrover paid about half. Always used main dealer for maintenance hence high price (but also, I guess, Landrover contribution).
You will struggle to get a warranty at this mileage and when something goes wrong it can be expensive - so a bit of a gamble on costs. If it was me I'd be heavily influenced by a comprehensive service history.
I've not taken any preventative action outside official service schedules - reading earlier posts maybe I should...
Post #562514 24th Jul 2020 12:51pm
Hammer
Hi johnf
thank you for that. Yours is the highest milage ive seen do far for the 5.0 supercharged, including searching rangerover.net
2007 TDV8 Vogue
Post #562579 24th Jul 2020 11:02pm
