Home > Camping, Caravanning and Holidays > Caravan brake lights don’t work
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
A neighbour has a new RR Sport, he’s just hooked up to his van, and all the lights work with the exception of the brake lights.
I’ve put my ff on and everything is ok, I did have to use an adaptor, as my ff has twin sockets, his sport obviously has single 13 pin.
Any ideas chaps?
Cheers
Post #562360 22nd Jul 2020 2:51pm
From what you’ve said, the caravan seems to be ok but there is an issue with either the connector or wiring on his car.
How new is it ?
Call LR Assistance ? They need someone to test the car.
Anywhere that fits towbars also probably has a plug in tester.....
Post #562363 22nd Jul 2020 3:18pm
Brian Considine
You can buy a 13-pin trailer socket tester ;
https://www.sealey.co.uk/product/563720373...a-approved
there are probably cheaper alternatives.
Is it possible that the that the trailer brake lights circuit is fused separately ? Is there a possible LED/Bulb comparability issue ?
Otherwise it's a case of checking the pin connections carefully & then tracing through. 2003 Range Rover Vogue TD6
Post #562364 22nd Jul 2020 3:23pm
Range Rover LSE
I had a similar problem with the first L405 I had a few years ago. I got the AA and there were fuses blown. They were located behind the glovebox. Range Rover Sport 2023 D350 Autobiography
Gone RR L405 Autobiography SDV8, RR L405 VSE SDV8, RR L405 3.0L VSE, RR L322 BM 4.4, RR Sport, RR L322 TDV8 Vogue, Disco 4, Disco 3 (2 off), Disco 2 and RR Classic & RR LSE
Post #562398 22nd Jul 2020 10:00pm
Wogger
Thanks for the replies chaps
I think it was fuses.
Post #562521 24th Jul 2020 2:14pm
