![]() | Home > Technical (L405) > Seat Belt Engine Stop |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
If you have stop / start enabled and it activates when you stop, if you remove your seatbelt the ignition will auto shut off, gearbox goes to P if you open the door |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 339 ![]() ![]() ![]() |
Many thanks for that.
basil Member Since: 09 Dec 2014 Location: UK Posts: 88 ![]() ![]() |
My understanding (experience) is that Start/Stop does not need to have stopped the engine (but it needs to be switched on). If the car is put into Park, and the hand brake applied, then he drivers seat belt unlatched then the engine will switch off.
Jon
ADI Member Since: 13 Oct 2017 Location: South Yorkshire Posts: 70 ![]() ![]() ![]() |
Yes disabling stop/start will prevent this happening. BMW X3 30e XDrive M Sport
Brilliant, many thanks. |
