Home > Off Topic - Other Cars > Days are numbered for Range Rover !!
Page 4 of 4 <1234
Weegie
Boxbrownie wrote:
Our Daughter can just get to us from Norfolk (262 miles) in one go......getting close though, last time she had just 10 miles range left.... Whistle
Wonder how it will fare in the winter months with lights and heating etc all working. John
GAP iiD BT-Sold
Post #561892 18th Jul 2020 12:38pm
Yip, range anxiety is still an issue to a lot of people, myself included.
If they could produce a car that has a theoretical range of say 1000km, giving a real life range in all conditions of say 500km, I might reconsider.
Oh and the price is reasonably affordable and the batteries don’t need replaced after 3-5 years.
Not in my lifetime, I rather suspect. Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #561893 18th Jul 2020 12:45pm
MarkinNantwich
United Kingdom 2011 Range Rover Vogue TDV8 Ipanema Sand
Charging time at home would be an issue, local supplu isn't that good at best. I don't know how many AMPS are available to this house but I'm sure the charging time would be impacted.
Post #561912 18th Jul 2020 4:37pm
Brian Considine
Most domestic properties have an 80 or 100amp fuse in the supply companies cut-out.
You should be good for at least 50 odd amps. However, if you have storage heaters..........
It also depends on how good the grid is in your area - it's designed on the basis that not everyone draws full load at the same time. Look forward towards more power cuts or "brown-outs" as the use of EV's increases.
I have a 1923's built house & the incoming cable is the equivalent of 6mm2 (which is generally rated around 40 amps) - but I have a 100amp fuse to "protect" it. The incoming voltage goes up & down like a yo yo but National Grid will not do anything about it until it fails completely.
In the meantime EDF get a bill every time something like a central heating controller fails (they always argue, but always pay up in the end - after all, they are providing a faulty product".)
Next time you see Nation Grid guys working on the network ask them how well the older parts will cope.......... 2003 Range Rover Vogue TD6
Post #561951 18th Jul 2020 6:52pm
MarkinNantwich
Almost everything is electric except a gas hob on LPG, electric here can be difficult at times of peak demand
Post #561954 18th Jul 2020 6:55pm
Brian Considine
If there is no mains gas in your area then a lot of people will have storage heaters so not too much capacity left for charging up electric mice.
At least most electrical equipment thesedays is quite tolerant of yo you voltages - I'm old enough to remember when the picture would shrink in the old 405 line TV's when the voltage was down ! 2003 Range Rover Vogue TD6
Post #562027 19th Jul 2020 8:57am
Page 4 of 4 <1234
