![]() | Home > Technical (L405) > Eco stop start |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Um, yours shouldn't have stop start i don't think sir? 15MY> was factory fit...
Hendersonmum Member Since: 02 Mar 2019 Location: Salisbury Posts: 9 ![]() ![]() ![]() |
Yes definitely got one, has a button on centre console. It used to work.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
i'd be thankful it has stopped working..personally i find it an irritation.. ... - .- -.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
I agree with Stan TBH it is an irritation, but if you want it working after a Battery change you need to reset the BMS with a diagnostic tool, I used Autel 806 Pro, but I'm sure the IId tool will do the same. I don't remember it showing a fault code either, just the re-set did the trick. |
As well as resetting the battery you also need to A, have enough charge in the system! & B, have your AC switched on and to a suitable temperature (near achievable) otherwise it won’t work as it’ll be trying to achieve your heat/cool |
