![]() | Home > Range Rover Classic > Sunroof opened a bit and then stucked |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Try a allen key in the hole ( centre of large nut ) |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 ![]() ![]() ![]() |
fuse? There is nothing that can't be fixed with a hammer😜😜
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
When new they were supplied with a wrench / key in the tool kit to manually operate the motor - it fits in that hole on the motor in your pic. If yours has the original tool kit it will be in there. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7847 ![]() ![]() ![]() |
I didn’t think they made them with steel sunroofs...... every day is a learning day....
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
I've never seen a metal sunroof on a 322. Could it have been custom made/replaced or custom ordered?
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
The OP is referring to a classic guys!..... Dooooh |
Yes as said above you need to put the CORRECT SIZE allen key in the centre of the bolt hole and close/open it manually sir |
You both need to stay behind after school today and do 500 lines... 😱😏🤭 |
flashgordon Member Since: 23 Sep 2019 Location: Hannover Posts: 76 ![]() ![]() |
Ok, issue is SOLVED now by a mechanic.
That’s good. Got there in the end. I’d need a working sunroof.
