Home > Range Rover Classic > Sunroof opened a bit and then stucked
flashgordon
Germany
When opened the sunroof (for the first time since 20 years I guess)
it opened a little bit and then stopped - no back and forth , no noise.
I opened the small cover in the headliner and knocked carefully against the silver-colored relay but nothing changed.
Is there a possibility to close the sunroof manually ?
How would you proceed ?
Post #550801 18th Apr 2020 2:04pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Try a allen key in the hole ( centre of large nut )
Post #550849 18th Apr 2020 5:47pm
fuse? There is nothing that can't be fixed with a hammer😜😜
Post #550851 18th Apr 2020 6:00pm
Vogue
When new they were supplied with a wrench / key in the tool kit to manually operate the motor - it fits in that hole on the motor in your pic. If yours has the original tool kit it will be in there. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #561512 15th Jul 2020 3:06am
mjdronfield
I didn’t think they made them with steel sunroofs...... every day is a learning day....
Yes.... turn the Allen key....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #561536 15th Jul 2020 8:58am
verydisco
I've never seen a metal sunroof on a 322. Could it have been custom made/replaced or custom ordered?
I don't really see the point of this option though - then again I'm not a fan of an opening roof, but definitely like glass roof Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #561543 15th Jul 2020 10:03am
The OP is referring to a classic guys!..... Dooooh Thumbs Up
Post #561545 15th Jul 2020 10:10am
Yes as said above you need to put the CORRECT SIZE allen key in the centre of the bolt hole and close/open it manually sir Thumbs Up
Post #561546 15th Jul 2020 10:11am
mjdronfield
Rolling with laughter OMG.... I looked at the ridges in the roof and still didn’t twig.
It’s in the Classic section too. That’s what happens when you just click on New Posts and go up.....
I’ll get my coat.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #561557 15th Jul 2020 11:23am
You both need to stay behind after school today and do 500 lines... 😱😏🤭
Post #561558 15th Jul 2020 11:31am
flashgordon
Germany
Ok, issue is SOLVED now by a mechanic.
Alan key /wrench didn‘t help in that case as a cable was in the way and has bend something ...
fortunately the previous owner - a Range Rover mechanic - replaced the parts (even when it took a while).
Works fine now.
Post #561744 16th Jul 2020 8:23pm
mjdronfield
That’s good. Got there in the end. I’d need a working sunroof.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #561746 16th Jul 2020 8:47pm
