![]() | Home > Technical (L322) > LTB00454 Update. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Whilst the LTB refers to cruise control at motorway speeds, at that speed the engine is still at quite low revs and on light throttle. On motorway hills on CC the gearbox drops a gear so the conditions mentioned in the LTB no longer apply.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1266 ![]() ![]() ![]() |
Thanks for the reply. I presumed you could have just a specific numbered update done. Are you saying that if I have a software update that it will update everything available?
If you ask for the update for this LTB then the PCM will be updated to the latest level which is likely to include updates for other improvements but only for the PCM. You would have to ask for either all ecus or just specific ecus to be updated to the latest levels to have them updated. My local dealer wouldn't update all ecus but updated a couple of others at my suggestion hoping to resolve other issues that were being experienced, being the centre display often restarting shortly after start-up which may have been overcome with a BCM update or updates to the display etc and a gearbox update if available in case it helped with the excessive torque convert slippage on take-off and after slow street corners. The BCM and display ecus were updated but the gbox was already at the latest level. The IIDTool says that the drivers and passenger front door modules and a few others are back-level but I didn't bother with those. |
I really appreciate your input on this. I will get the PCM updates done and keep my fingers crossed. Thanks Kev. |
Kevin, it maybe worth checking out the remap route sir? Ive had lots done due to customer complaints about dead or flat spots... Its always solved these problems on my own & customer cars sir |
Thanks Craig. My dream car is spoiling my expectations and it drives me insane when I can't fix it. I've [finally] managed to get a diagnostic slot at a MD on 5th August. They seemed very vague about updates and never heard of the problem I'm having. Only to be expected!!! It seems nowadays that if the diagnostic machine shows nothing they don't have a clue.
I’ve sent you a PM sir |
