Home > My Range Rover > Project Fatty Onroader 5.0 Supercharged
Page 9 of 17 <123 ... 8910 ... 151617>
this is for the L405 and info found in the WM,
Post #559699 30th Jun 2020 8:53pm
That's posh, just checked the manual, the 322 just tells you when a tyre is underinflated, no way to see the pressures.. Pete
Post #559703 30th Jun 2020 9:38pm
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
What’s the speed rating on those take off tyres, Pete?
When I looked I couldn’t find any with a Y rating, they were all W rated, which I thought weren’t suitable for a SC.
Post #559718 1st Jul 2020 6:39am
I did look into it and came up with this....
These new ones are 255/55/19 110W
Land Rover list suitable tyres in the handbook rated at Y (186mph) V (149mph) and H (130mph) as well as the daft spare at M (81mph)
W rating is up to 168mph.
They list load rating at 109 (1030kg) and 111(1090kg) mine are 110 (1060kg)
So these tyres specifications come within the parameters set by Land Rover
The S/C is limited to 140mph so no speed issue
Weight is well within the capability of the tyres.
I'm happy with that and I don't think the insurance company would have anything to moan about... Thumbs Up
The handbook is for both S/C and TDV8, there is no mention of different tyres for each model... Pete
Post #559727 1st Jul 2020 8:28am
GGDR
...you also need to get rid of that widow-maker scissor jack Pete.
. Cheers, Greg
Post #559728 1st Jul 2020 8:32am
Greg, you missed this post...!
Haylands wrote:
And yes, just haven't got round to throwing the jack out.... I'd call out our breakdown service if I get a flat, not chancing jacking 2.7 tons by the side of the road, even with a Sprinter jack..!!
 Pete
Post #559730 1st Jul 2020 8:45am
GGDR
. Cheers, Greg
Post #559733 1st Jul 2020 8:59am
xjsracer44
Thanks for your detailed reply, I like your thought process Thumbs Up
I toyed with the idea of take offs, having bought some direct replacement L322 take offs previously from Duckworths. Decided to buy four new 109Y Pirelli Scorpions instead after reading reviews on here, as had been running Continentals since 2007.
Post #559761 1st Jul 2020 12:16pm
GGDR
Pete have you seen this:
&t=198s Cheers, Greg
Post #561630 15th Jul 2020 9:11pm
The 405 Tpms may be posh.....
But it’s pressures are a bit wrong According to my pressure gauge. There is nothing that can't be fixed with a hammer😜😜
Post #561632 15th Jul 2020 9:27pm
Hmmmmm not sure whether he liked it much at all??????
Post #561647 16th Jul 2020 1:17am
mjdronfield
Rolling with laughter I watched it. Think I’d get bored of it after tearing about for a bit, and you will definitely get pulled over in the UK I recon.
Think I prefer a deeper sound with less “rasp”.
It’s trying a bit too hard....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #561665 16th Jul 2020 8:03am
Really NOT befitting a RR Whistle Whistle Whistle
Post #561669 16th Jul 2020 8:28am
Sorry, been away for a few days... what an absolute piece of Censored
How to make a nice RR into a tacky tasteless piece of Censored
The RR police should seize it and return it to stock....
And don't get me started about the low life who presents the video....
And yes, I am a snob.... Thumbs Up Pete
Post #562066 19th Jul 2020 8:34pm
Got a day in the garage yesterday, persuaded my mate to let me do a gearbox oil change following the one I did with my last fatty which ended up with a 5ltr slick on his nice floor..!! Everything went well this time and not too much debris on the magnets.. Gearchanges are noticeably smoother, I'll do another drop and fill soon... (lets not have a drop and fill verses flush discussion on here please..!!)
Stripped the rear brakes, cleaned up the calipers and disc top hat, painted them in metallic black and fitted new hardware and pads, looks much nicer through the wheel now...
Managed to fit the Sprinter jack in the same cradle the scissor jack was it... keeps it very secure and out of the way, the three piece handle is in the grey bag bottom right of picture.. Very pleased this is all sorted...
Replaced the top of the fuel delivery system in the tank, it contains a filter that is recommended to change at 10 years, I was hoping it was the cause of the fuel pressure dropping after several seconds of full throttle, the fatty was hitting restricted performance after about 4-5 seconds of full throttle, live values showed the high pressure pumps pressure dropping well down.. The new filter has helped, it now takes around 8-10 seconds to drop off... I can't understand how a mechanical pump can achieve the required pressure for some time, then drop off if the pump is faulty, it still looks like a supply issue, i.e. the high pressure pumps are not getting the amount of fuel they require... You can sit all day at 3/4 throttle with no issues and the live values show the pressure at 3/4 throttle is the same as full throttle but with no delivery issues...!! Anyone any ideas..?? Pete
Post #562485 24th Jul 2020 8:56am
