![]() | Home > Technical (L322) > Inhibitor |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi Glen, how did you end up sorting the issue? New unit altogether?
glenhendry Member Since: 14 Jan 2019 Location: Brisbane Posts: 12 ![]() ![]() ![]() |
I bought a 2nd hand unit for 250aud and installed it and all is fixed. |
LPG L322 2002 Member Since: 16 May 2021 Location: Midlands Posts: 3 ![]() ![]() ![]() |
I had the common Trans Failsafe Mode pop up intermittently a few months ago, then pretty much every time I started the car more recently. My workaround was as suggested and to start it from Neutral. Got fed up with the starting procedure eventually, so decided to investigate at the weekend and try and sort.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
The angular orientation of the switch should be fixed relative to the casing as it is located by the selector shaft and a dowel pin. The bolts just stop it falling off.
Hi Phil, thanks for the picture and explanation. Makes much more sense like that, than lying on my back under the car!
