![]() | Home > Technical (L322) > Inhibitor |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
According to the ZF parts manual the Inhibit switch is unique on the LR and is not interchangeable with others. Checking confirms the cabling is longer for the LR version. Parts manual available here: http://www.e38.org/ZF_5HP24_Spare_Parts.pdf I see they have gone up even more in price since I changed mine 5 years ago. Try an OEM part, some I've seen are actually warrantied longer than genuine LR (2 year v 1 year) and are cheaper. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
You can see in the photo below the difference in the wire length (though both the switch and the connector are identical in each case) :
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8531 ![]() ![]() ![]() |
So a bit of soldering and it's half price.... |
Damn if I had known that was the only difference I would have done as Haylands said, chopped and soldered the old connector lead on a new BMW switch.
lyonsimo86 Member Since: 26 Apr 2016 Location: Hull Posts: 3 ![]() ![]() ![]() |
Got an OEM part on order from LRDirect, 2 year warranty for just less than £350. Although the BMW part is £125 cheaper don't fancy voiding any warranty with my soldering skills. |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
I got a second hand one off of ebay in the USA for just under £50 delivered to Scotland and it has been fine for the last 12 months.
jjcbollen Member Since: 25 May 2016 Location: Maastricht Posts: 6 ![]() ![]() ![]() |
Hmmm, I have a RR Vogue 4.4 v8 petrol from 2003 and when the temperature is around zero degrees (Celsius) and the weather is wet or moist I seem to have "a" problem with my RR.....
Next time the engine fails to crank you should check if ‘P’ is illuminated on the instrument panel.
Hi RRPhil,
The inhibitor switch indirectly provides the signal to the instrument display so if the ‘P’ was not illuminated when the engine failed to crank this would indicate an inhibitor switch fault (or selector cable adjustment issue).
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
Hi. I currently have an intimitant problem with our inhibitor switch . Only very occassionaly the p does not appear on the dash so obviously won't let you start the car. Would it be worth while and easy enough to take it off, open it and clean it? |
The inhibitor switch also allows the engine to be started in Neutral, as well as Park, of course. The two halves of the switch are held together by rivets so you would need to drill the heads off these to disassemble it and then re-rivet it (or similar) back together again once cleaned. As the switch is exposed to the elements under the vehicle it’s important that its seals are doing their job properly (there’s two for the shaft and one for the casing) so you’d need to be careful with these. Clearly, individual parts aren’t available for the switch so if anything is broken (like one of the wiper fingers, for example) the chances are that you’ll have to replace the whole switch. Having said all that, it’s easy enough to remove and replace and new ones are ridiculously priced so I would say, yes, give it a go.
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 ![]() ![]() ![]() |
I did clean up my inhibitor switch some time ago and fault has stayed away since. Grease inside had turned to wax and contacting wipers were not strong enough to push through it to make proper contact. |
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 ![]() ![]() ![]() |
Sorry to resurrect an old post, but I have had a similar problem to this, with trans failsafe warning, with P being displayed. It happened in Germany recently, a mechanic came out, tapped the starter motor with a hammer and the engine turned over, so thats what i'm doing until i can get the car booked in. In my case I think it is the starter at fault because when I tap it and someone else turns the key, I get a spark/flash. All connections seem tight. Strange! |
