Home > Maintenance & Mods (L322) > rear wipe problem L322
mjdronfield
Ahhhh, the joys 🤣 I’m not sure if they did the same on the X5, never had one so don’t know. I assume they learnt and do something different now.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #561538 15th Jul 2020 10:03am
billybob
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
pulled the motor out of tailgate today, rusty marks around centre shaft and some rudt water stains inside the plastic tailgate trim, dead short on motor, so its another motor now. I have also unblocked the washer jets and next will be looking at pump.
Deep, deep joy!! Oh yes, and deep deep pockets!
Post #561577 15th Jul 2020 2:16pm
mjdronfield
It was always gonna be a new motor. Had a new one on my TD6 and never had any issues after.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #561580 15th Jul 2020 2:58pm
billybob
Yep, it should resolve the problem, I also ordered a new pump as I guess its burnt out, thanks for your advice.
Post #561581 15th Jul 2020 3:04pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Being serious for a moment, I'm sure there was a write up on here some time ago about the rear washer and a mod(?) that could be done to improve the seal around the washer tube.
Try using the search function.
(And all Range Rovers have a secret wallet emptying chip.....)
Post #561590 15th Jul 2020 4:21pm
billybob
I'll take a look, see what it says, well, I will if I can find it.
As for emptying wallets, I havnt learned from previous mistakes, 1 disco, 2 freelanders a P38 and now this L322. It;s over, I have instructed family and friends to do anything needed to stop me ever buying anything that comes out of land Rover.
Once this one goes, the affair is over!!
Post #561594 15th Jul 2020 4:45pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
The write up is in the Wiki and it's a dead easy job. I fitted a new unit myself and about 4 inches from the pump is the non return valve. Take that out and see how much water comes through when you switch on the rear washer. Have your beautiful assistant hold the pipe and you can usually drown her. Te he. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #561596 15th Jul 2020 4:51pm
billybob
I'll see what my beautiful assistant says about holding my pipe to be caught out by the water. I feel a slap coming on.
Post #561601 15th Jul 2020 5:22pm
