Home > Technical (L322) > 020 Battery Doesn’t Fit in my MY10
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Having spent a lot of time trawling through the forum looking for confirmation that an 020 battery would fit in my car, I couldn’t find absolute proof. A look on the Tayna website showed a few comments from owners who had fitted the Varta 020 in a Range Rover (one starting 3.6TDV8) so I took the plunge.
Starting the job in brilliant sunshine it became obvious it would be a squeeze but I was determined.
Old knackered 019 Bosch out and then the fun began.
Removing part after part it became obvious that the windscreen scuttle also had to come off. Then the thunderstorm arrived so bonnet back down as it resembled a sail in the upright service position, and I ran inside for half an hour.
Once the sun came back I continued. New battery lifted up and over for the twentieth time and it went in!
Battery securing clamps tightened and all was looking good until I tried to connect the positive clamp.
Due to all of the technical gubbins on the positive lead, which had previously slated nicely down the side of the 019 battery, I realised it wasn’t going to happen without some serious metallic modification.
So new battery out, old one back in and on charge and the car reassemble. Well, almost. During the stormy weather two scuttle clips had disappeared - does anyone know the part numbers??
What’s the point of this thread you may ask?
It’s to give others the heads up that the 020 battery will not fit in a MY10 3.6 TDV8. That’s all.
Thankfully Tayna are delivering an 019 today and exchanging for the cost of the carriage (about £7) so all should be good soon.
(Finally, if he reads this, Stan; good call. I can’t abide rudeness from members on what is a very friendly, helpful and well mannered forum). 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #561518 15th Jul 2020 8:35am
i have read this and thank you ...your comment is appreciated Wink .
and thanks for the info re the battery.. Thumbs Up ... - .- -.
Post #561521 15th Jul 2020 8:49am
EDWARD757
2007 Range Rover Vogue SE TDV8 Java Black
With our 08 3.6 RR I had to place some blocks of wood beneath the battery to raise it enough so the positive terminal would have enough room. I then used two narrow ratchet straps to hold it all in place. An utter ballache getting it in and out but works well until workshops repeatedly start and stop the car, killing the battery. Fortunately I have claimed on the ECP five year warranty a few times to have a battery that hasn’t been flattened ever.
As an aside, one issue we did discover was the surrounding bodywork does sit under the positive terminal and hitting a bump on, say, entering a car park can break the connection by just enough. So car Runs perfectly. Shutdown for five minutes and on return the car is totally dead. Main dealer repeatedly could not find a fault but an indy spent twenty minutes and diagnosed as the positive terminal not being properly seated. The positive terminal is slightly conical shaped so ensure the clamp is all the way down and tighten appropriately.
Hope you get Things sorted.
Kind regards,
Ed '96 Volkswagen Polo 1.4CL - SOLD
'00 Audi A3 1.8T - SOLD
'97 Lotus Esprit V8 - SOLD
'03 BMW M3 - SOLD
'93 Range Rover 3.9 Vogue SE - SOLD
'92 Peugeot 205 GRD - DIED
'99 BMW 540i Touring - SOLD
'94 Peugeot 405 GDRT - SOLD
'00 Peugeot 406 HDI estate - 63mpg! - SOLD
'08 Range Rover TDV8 Vogue SE - SOLD
'11 Skoda Fabia Greenline II - 94.2mpg!- SOLD
'07 E61 BMW 530d msport touring - SOLD
‘20 Tesla Model 3 SR+
‘20 Tesla Model 3 Performance
Post #561527 15th Jul 2020 9:14am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Correct Sir, later cars struggle with 020 -- I posted a thread on this regarding 4.4 TDV8 Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #561541 15th Jul 2020 10:35am
WB
That's great info re the battery - I wonder if the 5.0 has the same issue as there's a lot of electronics and wiring in the battery compartment.
I've just been looking up scuttle clips and they are:
EYC101450 - underside part
cyc000010 - top black clip
Post #561553 15th Jul 2020 12:06pm
chris_read
Thanks for the part numbers. That’s really helpful Thumbs Up 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #561562 15th Jul 2020 12:44pm
chris_read
Bushy - I saw your thread about the 4.4 not being able to accommodate one but was hopeful that mine, being the smaller engine, would be ok.
Perhaps if I had measured the space beforehand..... Embarassed 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #561563 15th Jul 2020 12:46pm
mjdronfield
I think you have to cut and file chunks of the battery from what I’ve read on here.
I’ll fit an 019 to my 4.4 TDV8 when I get one. Can the idea of the 020.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #561566 15th Jul 2020 1:00pm
GGDR
but somebody has done one in a 4.4TDV8
let me think who that was....
Dolph34 I think
. Cheers, Greg
Post #561567 15th Jul 2020 1:03pm
mjdronfield
Yeah.... then somebody else tried and said no way..... so still didn’t get a definitive answer.
If you use a garage, I can’t see them mucking about to try and get a different part to fit.
I need a battery, but not using the car much currently, and the CTEK is plugged in.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #561568 15th Jul 2020 1:10pm
chris_read
A Varta H3 has now arrived and is currently on charge (see what I did there Rolling with laughter ) 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
Post #561571 15th Jul 2020 1:20pm
RJDS
United Kingdom 2011 Range Rover Autobiography TDV8 Bournville
There was another post a few weeks ago about fitting an 020 to a 3.6 TDV8.....
You can certainly fit an 020 to a 2008, There is no way on this earth you’ll fit an 020 to a 2010 without some surgery to the battery. 2011 TDV8 4.4 AB Bournville Brown
Post #561579 15th Jul 2020 2:50pm
