![]() | Home > Technical (L322) > L322 2010 3,6 Restricted performance |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8687 ![]() ![]() ![]() |
Not sure the error is necessarily linked to the restricted performance.
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
yes i checked these very detailed and didnt find any split or tear, do you have any photo of "your split" please?
No pic. Did the write up after I had fixed the split.
ok thank you i got them off today too but i will check both tomorrow again just to be sure
that might work, but usually if they have a hole in them then its pretty obvious once they are off. There is nothing that can't be fixed with a hammer😜😜
today i checked hoses to differential sensors - looks ok, no splits or so, i tried to swap them but no luck, error is still on bank1
okay we are in blind end here ...
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
DPF on a 3.6? Mines a 2010 3.6 and hasn’t got them?
really 2010 3.6 (with interior facelift) and i got them |
My EGRs are blanked off mechanically and also in the map itself. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
well i try to take DPF (bank1) to cleaning service and after that, car fails on P244B-00 (bank2) so i pull out second DPF and do the cleaning ... everything goes OK
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
The parts catalogue shows that the 2 rear sensors are the same and the 3 front sensors are the same although different to the rears, indicating that the sensors can be swapped left and right. Perhaps swap the rear sensors then see if the fault remains on the same bank but if swapped then the rear sensor is most likely faulty. If no difference then swap front sensors then check if the fault has swapped sides. |
rear sensors are swapped and that one on bank1 even replaced - same error and values
Sorry, I misread the descriptions as the sensors are temperature sensors, not pressure.
