Home > Technical (L322) > L322 2010 3,6 Restricted performance
sergeiicz
Czech Republic 2002 Range Rover HSE Td6 Epsom Green
yes these pressure sensors were swapped and even replaced before
and no i never swapped temperature sensors, they are all "baked" to exhaust pipe so strong that i was feared to broke them
anyway today i put back original software (without egr off and remap) to ECU and order one new EGR valve to replace broken one as i found some similiar issues with remap or EGR off on cars with DPF and all these troubles started like 1500kms before EGR off + remap
GraemeS i found that you trying or did EGR off on car with DPF right? if yes everything working ok so far?
thank you
Post #565402 24th Aug 2020 11:28pm
GraemeS
Australia
Mine's a 4.4 without DPF and still has EGR operational.
Post #565413 25th Aug 2020 3:59am
GGDR
Can't talk about the 3.6 but on the 4.4TDV8 the sort of problem you are having would typically be an air system leak. Suggest you try to get a smoke test but it would need to be a high pressure smoke test. Low pressure smoke tests won't be good enough to find a leak.
Not sure that the 3.6TDV8 came with a DPF here in the UK so possibly not too many people have your set up (3.6 with DPF) but I may be wrong.
. Cheers, Greg
Post #565415 25th Aug 2020 7:50am
