Home > In Car Electronics (L322) > l322 2003 voice & phone
Page 4 of 4 <1234
tommo10ferrets
England 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Update
Thanks for that MJ, I think I'm going to take the heater control facia panel out & have a look for the mic cable running down behind it, may give me a better indication as to where it is in the centre console, if i can see it, a gentle pull on it may dislodge it a bit to enable me to get hold of it...........hopefully that is!!!!!
regards
Tommo
Post #560396 6th Jul 2020 5:32pm
mjdronfield
Getting there slowly. You made absolutely sure the connector isn’t tucked behind the sunroof switch? I know you probably have, but sometimes they are well hidden behind the headlining.....
Don’t want you to rerun wires only to then unearth it......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #560402 6th Jul 2020 6:54pm
tommo10ferrets
Update
Morning, I'll have another look later today inside the light unit, one thing i did notice when i connected the mic to the plug in the light unit was that there wasn't any slack, it was very tight, so maybe it is tucked away inside head lining, we'll see, have got a bit of a noisy water pump, so have ordered a new one, should be here Wednesday or Thursday, probably fit it over the weekend, no problem with over heating or anything, just being safe, had a "whump whump" noise, so got a stethoscope on it to trace the sound , got loud when i put it on the pump hence swopping it out.
Regards
Tommo
Post #560431 7th Jul 2020 6:38am
tommo10ferrets
Update
Afternoon, took the heater facia panel off, took out the overhead light fitting, got the centre console lifted up so i could see all the cables underneath, no screened cable for the mic there, the wiring in the over head light seems to run to the right towards the screen piller, i presume it then drops down & then runs across back towards the centre console, so i think its tucked away along that route somewhere, think it will be easier to run another cable from the rear to the mic in the light fitting, i think i may get auto electrician to give me a price, so frustrating,
Inside facia.
Underneath ignition switch.
Inside facia.
The only 3 plugs in there, all single wire, yellow & white/grey, not screened.
Regards
Tommo
Post #560485 7th Jul 2020 11:54am
mjdronfield
I guess you can’t search any more than that really. It will work well when it’s finished.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #560501 7th Jul 2020 1:48pm
tommo10ferrets
Update
Morning all, hope everyone still save & well, the new water pump turned up last week, went ahead & fitted it, noticed when i took it out that the 3/4" hose connected from the heater control valve to the pump had a "O" ring on it, also had a collar on it which was also loose, thought this was strange, anyway, took the o ring off & reconnected the pipe, put everything back, filled & vented system, all ok, checked for leaks, let the car run until up to temp, turned engine off, put all tools away, closed bonnet then noticed water pouring out!!!!! investigated, found that the hose that had the "O" ring on it was leaking, so stripped down again, took off the hose completely, found that the collar was in fact part of the fixed sealing part of the hose, obviously the previous owner had a problem with it & instead of just buying a new hose (£25) put the "O" ring on to seal it, So have fitted new hose, everything fine now. Back to the mic, took the mic out of the light binnacle & plugged it straight in to the lead from the rear of the car (which will be in the centre console) and made a phone call, worked great, clear as a bell both ends, so I'm going to take dash out this morning & see if i can find other end of mic cable, i lost its path after the front "A" pillar, in the mean time I've ordered a couple of BMW 3 pin connectors, male & female ends just in case i can't find the other end & have to run in a new cable, they should be here later this week. Fingers crossed.
Regards
Tommo
Post #562088 20th Jul 2020 8:03am
mjdronfield
Slowly but surely.... do it right, do it once and all that....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #562090 20th Jul 2020 8:40am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Tommo,
Difficult to see from your pictures which side you are looking -- my cable wasn't under the ignition switch side, but the passenger side of the car and it was buried about as low as it could go, about in line with the front of the lid of the centre cubby, but passenger side. Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #562113 20th Jul 2020 1:28pm
tommo10ferrets
Update
Hello Bushy, had a look in that location the other week, virtually nothing on that side of the centre console, most everything seems to be coming from the right hand side of car ( ignition switch side) i can trace the mic cable from the overhead light to the drivers side front A pillar, it then runs down the side of the windscreen to underneath the dashboard, then i lose it from there, have had the radio & heater control panels out to see if it then runs underneath the centre console, nothing there, so i have decided to run a new shielded cable in, have stripped down everything in prep for the new plugs to turn up, hopefully next couple of days, motor looks a mess inside at the moment with all the front stripped out lol, will pull the new cable through in the morning & put everything back, so hopefully just leaves the plugs to connect.
But I will check your location again just to make sure.
Regards
Tommo
Post #562122 20th Jul 2020 3:00pm
Bushy30
Tommo,
Promise it's there ! I had to use a tone set and wand to find mine -- that's a bit of kit that generates a warbling sound down a pair of wires and then an amplification set that you can hear the sound on -- I would have never found it without that -- I appreciate you probably haven't got one of those Sad Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #562126 20th Jul 2020 3:27pm
tommo10ferrets
Success !!!!!
Evening all, All up & working now, ran a new cable from the rear plug to the mic, clear as a bell both ends, but no phonebook downloaded, think that's down to the ulf module, gen 3, think I need gen 6 upwards, been online & nothing suitable, but I'll keep checking, did find a fella in Spain that had a gen 10 & a gen 13 but he had sold them, anyway thanks to everyone who contributed advice / info, been very welcome.
Kind Regards
Tommo
Post #562619 25th Jul 2020 5:53pm
Bushy30
That's grand news Tommo, glad you're sorted
There should be, albeit old, for sale post on here for a gen12, I have it somewhere 😀 Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #562622 25th Jul 2020 6:25pm
tommo10ferrets
Hello Bushy, just looked through 10 pages of ads, couldn't see anything, I'll go through the rest tomorrow & see if any available
thanks for the heads up, I had forgot that there were ads on the site.
Regards
Tommo
Post #562625 25th Jul 2020 7:03pm
Bushy30
Tommo,
It's here:-
https://www.fullfatrr.com/forum/topic48698.html?highlight=ulf Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #562626 25th Jul 2020 7:11pm
mjdronfield
That’s good then. It works well once it’s up and running. If you find a later ULF and it says MIT SES on the label, it will also allow voice recognition to the RR systems, I might have said that already though....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #562811 27th Jul 2020 10:21am
Page 4 of 4 <1234
