Home > My Range Rover > 2004 Range Rover Vogue in Tonga Green
Page 2 of 3 <123>
Weegie
If your screen and number of buttons is the same as in the link then you definitely have the MOST system. The earlier models had additional buttons.
No need to look in the cubbyhole. John
GAP iiD BT
Post #560463 7th Jul 2020 10:07am
ChrisRRV
United Kingdom 2004 Range Rover Vogue 4.4 V8 Tonga Green
Yes mine is the same as the image, with the less bottons.
Does that mean dont even try to change the headunit then? Bar bypassing the amp from the boot to the front?
Post #560466 7th Jul 2020 10:17am
Weegie
That Android system is for the earlier models. What are you trying to achieve?
PS. Have a look here for some information. https://www.fullfatrr.com/forum/topic44977.html John
GAP iiD BT
Post #560467 7th Jul 2020 10:18am
ChrisRRV
Here’s my rear unit
Apologies for the flipped angle on the image Confused
Post #560472 7th Jul 2020 10:44am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
MY2005 -- with MOST -- the thick whits 'cables' are the fibre connections Smile
As others have said, you do have options, but not the android spoken about previously Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #560473 7th Jul 2020 10:50am
ChrisRRV
b**locks Sad
Ill have a read at that thread and see whats best to do
Post #560475 7th Jul 2020 11:06am
Sorry for being the bringer of doom sir... Censored but at least your not wasting any more time or monies buying/researching the wrong thing!
Post #560491 7th Jul 2020 12:53pm
Bushy30
C-T-C the bringer of doom Rolling with laughter Rolling with laughter Rolling with laughter Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #560493 7th Jul 2020 12:58pm
ChrisRRV
Better to know now I suppose
Seems like its not too bad just means a bit more money but i really would love bluetooth and spotify in the range
Side steps and some bodywork tidy ups first however
Post #560494 7th Jul 2020 1:08pm
ChrisRRV
Im going to keep this updated just to keep track of all the changes and maintenance carried out during my ownership
New CV joint [06/2020]
New Air Valves all round [07/2020]
New Supercharger Style Grill [07/2020]
Supercharger Side Vents [07/2020]
Dark Walnut trim upgrade with welcome lights [07/2020]
New RANGE ROVER satin silver lettering [07/2020]
New VOGUE satin silver lettering [07/2020]
On order, due this week
New Facelift Rear lights
New Clear side repeaters
Solution Finish purchased to revamp the slightly faded plastics
8x New spark plugs
1x New Coil Pack [Have a misfire on cylinder 6]
New Wheel bolt covers in satin black
New genuine centre caps
Will continue to update as I go along. Picture below was taken this evening after a well deserved wash and wax.
Chris
Post #562067 19th Jul 2020 8:42pm
ChrisRRV
8 plugs changed [27/07/2020]
Cylinder 6 Coil Pack changed [27/07/2020]
Two new number plate bulbs [27/07/2020]
Original centre caps fitted [25/07/2020]
New wheel bolt covers fitted [25/07/2020]
Some things noted. Oil in the cylinders, not a worrying amount but its still there so I think I'll need some new gaskets somewhere. After the plugs were fitted though the smoke filled my driveway lol
Short drive up the road and all is well thankfully.
Gas struts on the bonnet need replaced, sore head tonight after it come down on it during a light breeze. So thats added to the list.
Some more parts ordered so will keep updating as I go.
Thanks
Chris
Post #562855 27th Jul 2020 9:08pm
ChrisRRV
One of my spare cherished plates fitted today ...
Thanks
Chris
Post #562991 29th Jul 2020 1:34pm
ChrisRRV
Update 14/08/2020
Found some rot on the sills at the rear passenger doors.
Couldn't be bothered worrying about it so its going in this Tuesday to have it all cut out and new stuff welded in, only way to tackle it properly.
Rear sills, rear arches and wheel Wells into cabin will all be cut away.
So tempted to 2006 facelift it as my indicator lenses are fogging up and have broken clips so might just facelift next month as I have sourced the parts relatively cheap.
The spends continue ...
Oh and a new battery this month also courtesy of GSF
Thanks
Chris
Post #564565 14th Aug 2020 12:59pm
ChrisRRV
Update 30/08/2020
Oil and Filter change today at 72000 miles.
All welding has been completed. All new rear sills both sides. Had to have new jacking points fabricated also. I also got the lower wheel wells cut out and replaced. All have been tiger sealed and are awaiting paint some time in the next week or 2.
I had the inner and outer arches grinded back too just incase, thankfully just surface rust from a stone chip on the passenger side. These have been treated and sealed also. Will get it all painted at once including ........
2007 facelift kit which I just purchased. Headlights, bumper, washer jets, high pressure water pump and lower grills
Bought a few axillary parts new from BritishParts. New bottom valance for the front bumper and mid fin cover.
Need to sort wiring harness for the headlights from PowerfulUKLtd
Also need 2006 onwards plastic mounting bracket for the bumper too so if anyone has one that would be great.
Pics to follow
Post #565912 30th Aug 2020 7:11pm
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Yours must be a very early one with the Denso system, just out of interest how many later on is it from my VIN? Last 7 here A179572 - mine is still a BMW based system but appears to have been built in the July of 2004. 2005 E60 M5
2006 L322 4.2 SC
2020 Tesla Model S Long Range
2004 L322 4.4 Vogue, 2019 NP300 Navara, 2016 NP300 Navara, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C ,2001 330Ci Sport Track Car, 2005 650i Coupe, 2001 P38 Vogue, 2003 530i Sport Touring, 1999 P38 4.6 HSE, 2002 E39 M5, 1995 300zx TT Slicktop, 1997 M3 Evo, 1992 300zx TT Targa, 1998 323i Coupe
Post #565924 30th Aug 2020 9:35pm
Page 2 of 3 <123>
