Home > My Range Rover > 2004 Range Rover Vogue in Tonga Green |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 209 |
Hope you enjoy yours as much as I’m enjoying mine - eventually 😉 L322 TDV8 4.4 - current
30th Jun 2020 7:21pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3163 |
@chris RRv
30th Jun 2020 7:26pm |
ChrisRRV Member Since: 30 Jun 2020 Location: Belfast Posts: 104 |
Some pics finally
6th Jul 2020 8:19pm |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
Looks lovely to me. Fitting the android is a bit of a faff because of the need to run a extension cable from the rear up to the dash. You can test the unit first before removing all the trim by connecting it up in the boot.
6th Jul 2020 11:02pm |
Thanks mate |
7th Jul 2020 8:03am |
Parallel Member Since: 15 Nov 2018 Location: Essex Posts: 35 |
Car looks great. You just can't beat a green Range Rover in my opinion! |
7th Jul 2020 8:24am |
100% agree.
7th Jul 2020 8:26am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
You say in your first thread it has hardon kardon logic 7... that would signify either a later car or an AB car? Was this a mistake? I ask as this will make fitting an aftermarket or BMW head unit Much more tricky, if not nigh on impossible as that would make the audio Jag based!?! |
7th Jul 2020 8:27am |
Just going by the door cards on the car it says Harmon Kardon Logic 7
7th Jul 2020 8:45am |
So it would appear not to be a mistake? What does your head deck look like? A MOST bus system? Ie touchscreen? If so then it’s not a BMW system but a Ford/Jag system sir... And I believe MUCH harder to replace!
7th Jul 2020 8:57am |
Mines touchscreen, same as this
7th Jul 2020 9:05am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
From that information, you have a MY 2005 with MOST optics. Note well Craig's comments. It is not easy/possible to replace. John
7th Jul 2020 9:08am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 |
Photo of the inside of the rear left cubby would let us determine for sure.
7th Jul 2020 9:09am |
Ill get that image today |
7th Jul 2020 10:01am |
