Home > Technical (L322) > 2008 3.6 gearbox issue
dinger645
Hello, first time poster here and I have a problem.
Something is not right with my gearbox. When its warmed up and I accelerate normally (not booting it) the revs fluctuate and when it gets to 3rd and 4th gear (I think) it seems like its changing up and down rapidly. also the rev counter flutters a bit when cruising.
When I boot it the problem seems worse with the rapid changing.
The revs still fluctuate even in manual mode, I have trawled the forums and the net and found things like the solenoids need changing or the torque converter is duff.
Any help would be appreciated as I don't want to spend money on one thing to find out its another.
cheers.
Great forum by the way.
Post #559862 2nd Jul 2020 4:14am
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Hi,
When was the oil in the box and filter (pan) last changed? I would start with this for beginning. Use land rover TKY 500050 suitable oil. That would be zf lifeguard 6 or something that must have this specification. I am using liqui moly atf 1800 at the moment. RR HSE 4.4 2006 LPG
Post #559863 2nd Jul 2020 5:41am
DrRob
Agreed, get it serviced by someone who knows these gearboxes... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #559871 2nd Jul 2020 7:13am
dinger645
Thanks guys
I have no idea if the oil has ever been changed so I think I will get this done first.
Did you notice a difference in your gearboxes after you had yours done?
Post #560035 3rd Jul 2020 1:06am
Fox889
In your instance I would suggest a 'megaflush' where 99% of the oil is flushed out & replaced rather than a 'oil & filter' change which only gets 40%-60% of the fluid out.
Budget £300-£400 for this hopefully. If you're oil is shagged you'll soon notice the difference. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #560039 3rd Jul 2020 6:58am
Gunni
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
My experience for what its worth
Had mine megaflushed at 90k miles just after I bought it. Not sure this was a good idea just drain and refill sounds kinder to the box. Don’t reset adaptations. It will not do it any good apparently.
Started to get Rev fluctuations And clunky changes and what felt like slipping clutch.
Then the vibration started on the torque converter and changed at 105k mikes including gen filter and zf oil.
Haven’t done any solenoids and so far all good. Now on 115k Smooth as silk but not a cheap job. Should have done it all together and saved the first flush and oil fill.
Only my opinion but think the tc shudder will come about at some point So get it out of the way and enjoy the smoothness and knowledge you won’t have to pay out again. I wish I had. Jon
2009 3.6 TDV8 Vogue SE
Previous Land Rovers
Series 2 Land Rover petrol - loved it and want another
Range Rover classic v8 - loved it But glad i sold it
Series 3 Land Rover - Steering lottery But useful.
Land Rover v8 90 - Fast dirty & drank Fuel like a Boeing 737.
Post #560102 3rd Jul 2020 2:46pm
Nothing has the same specification of the ZF oil no matter what it says on the bottle, the oil will be to the same spec but it will not have the friction modifiers that the ZF oil has..! Pete
Post #560179 4th Jul 2020 10:19am
WB
Have a read on the ZF website and give ZF customer support a call. The ZF process is to drain, replace the sump/filter with a new one and fill with ZF oil they do not recommend a megaflush. After all would you change engine oil and leave the dirty filter? Bear in mind the age of your filter... I know there are fans of the the megaflush on here but best to do your research.
Post #560232 4th Jul 2020 4:59pm
nick4275
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Been there done that - fingers crossed for you.
Try a tube of Dr. Tranny instant shudder fixx (yes it's a real thing) and costs next to nothing
I did with mine and it did the trick for a while although ultimately it was the torque converter and I had to have it replaced. Sorted all issues immediately.
Post #560398 6th Jul 2020 6:20pm
dinger645
Update.
I changed the oil and filter (with ZF lifeguard 6) and while I was in there I replaced the valve body seals and tested the solenoids. All the solenoids were good so I slapped it all back together and it is running a lot better, not perfect but there is a vast improvement.
I am guessing the reason its not perfect is the fact there is still some crappy oil in there.
I'll keep you posted Smile
Post #562338 22nd Jul 2020 11:04am
