Home > Technical (L322) > How to fit the lower timing chain tensioner LHP000050 ?
Zain
Should this be fitted in its compressed position or extended position....OR does it not matter.
(I ordered the part from Rob at Duckworth and it arrived in its extended position).
thanks in advance!
Post #560093 3rd Jul 2020 2:27pm
johnboyairey
From memory, you fit it compressed, and then use something to release it... there is a online source of how to do the whole job, and it mentions how to do it.
Post #560122 3rd Jul 2020 7:41pm
Zain
Thanks for the reply but just for clarity its the tensioner that is fitted from outside ....into the engine block on the drivers side.
(i 'think' you may be referring to the tensioners that sit within the 2 small cam chains inside the block. Apologies if im totally wrong)
Post #560224 4th Jul 2020 3:44pm
johnboyairey
i meant the lower timing chain tensioner. you have to fiddle with the clip, to latch it, so it stays in, whilst compressed, and when fitted, it will pop out and remain under spring tension, when the oil pressure forces it out.
Post #560259 4th Jul 2020 11:00pm
