Home > Wheels & Tyres > new wheels - what nuts and valves
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
Just bought a new set of take-offs for my l322 (cheaper than just tyres!)
the original valves have been removed so can i just fit std valves and what nuts are needed?
Post #559810 1st Jul 2020 6:25pm
You can fit normal valves, don't know what year your fatty is but if it's a later one then the TPMS won't work
You need the post 2006 nuts, plenty on ebay.. Pete
Post #559826 1st Jul 2020 7:48pm
DrRob
Bearmach nuts equal to Genuine ones. Both will eventually rust, swell and not allow a 22mm socket onto them Banging Head Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #559829 1st Jul 2020 8:00pm
dexion7
its a 2010 3.6 and has old sytle NON tpms tyre valves so use the same nuts with normal valves? (is the hole in the wheel for the valve the same size?
Post #559835 1st Jul 2020 8:12pm
notanrdx
United States 2017 Range Rover TDV6 Fuji White
Don't know if you can get these in the UK, but Gorilla Nuts are quite good.
https://www.gorilla-auto.com/lug-nuts-page-09
Post #559837 1st Jul 2020 8:14pm
Yep... Pete
Post #559841 1st Jul 2020 8:24pm
DrRob
Or go solid nuts
https://www.ebay.co.uk/itm/Land-Rover-Disc...890.l49292
Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #559842 1st Jul 2020 8:32pm
dexion7
thanks fellas, 1 final question:
the original superchaarger wheels are 8.5j 58 offset and these new ones are 9j 45 offset so will the wheels stick out a bit more?
Post #559874 2nd Jul 2020 7:19am
The extra wheel width should balance with the change of offset - maybe a slight difference, but I doubt it would be visible.
Post #559878 2nd Jul 2020 7:28am
They will look exactly like haylands car.... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #559981 2nd Jul 2020 5:18pm
Yep, he has good taste... Thumbs Up Pete
Post #559982 2nd Jul 2020 5:26pm
dexion7
Blimey, i wasn't wanting a colour change only new wheels!
Post #560053 3rd Jul 2020 8:31am
dexion7
ok, so my new wheels and tyres arrived - they look good but they have no valves in them.
given that they originally had TPMS valves in and I don't want those type, will normal valves fitted instead lead to a balancing requirement?
only the outside bead has been broken to remove the TMPS. Anyone know if std valves are the same weight as the TPMS?
also, has anyone self-fitted new rubber valves into the rims?
the guys at the tyre shop seem to just lubricate them and pull then through with pliers then pressurise to seat the bead back on.
Obviously I could just take all the wheels to a tyre place but these are big and heavy things and I'd need to do two trips so doing it myself if possible would be preferred.
Post #560114 3rd Jul 2020 4:53pm
dexion7
standing the new wheels / tyres next to those currently on the car and the new ones are about an inch greater OD.
20/50/255 V 20/55/255
Post #560123 3rd Jul 2020 6:49pm
They will need balancing
Lots of peeps running the 55’s on the L322 without a problem
You should be able to get all, 4 in with the seats down ?
Then get the tyre place to fit them whilst you’re there
Post #560125 3rd Jul 2020 7:54pm
