![]() | Home > Wheels & Tyres > new wheels - what nuts and valves |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8529 ![]() ![]() ![]() |
You can fit normal valves, don't know what year your fatty is but if it's a later one then the TPMS won't work
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Bearmach nuts equal to Genuine ones. Both will eventually rust, swell and not allow a 22mm socket onto them |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
its a 2010 3.6 and has old sytle NON tpms tyre valves so use the same nuts with normal valves? (is the hole in the wheel for the valve the same size? |
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 ![]() ![]() ![]() |
Don't know if you can get these in the UK, but Gorilla Nuts are quite good.
Yep... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Or go solid nuts
thanks fellas, 1 final question:
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
The extra wheel width should balance with the change of offset - maybe a slight difference, but I doubt it would be visible. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
They will look exactly like haylands car.... |
Yep, he has good taste... |
Blimey, i wasn't wanting a colour change only new wheels! |
ok, so my new wheels and tyres arrived - they look good but they have no valves in them.
standing the new wheels / tyres next to those currently on the car and the new ones are about an inch greater OD.
They will need balancing
