![]() | Home > Technical (L322) > Engine system fault |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
I don't think it's the voltage and it's a bit low but depends how much stuff you have on.
In fact checked back and this is the code and exact symptoms I had with the cracked manifold. Diagnosed mine with some soapy water on it to see it bubble. Hopefully it's just the top hoses for you though |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 214 ![]() ![]() ![]() |
I thought the hoses but I have changed them but it was about 4yrs ago .a quick visual check and they look fine,my voltage has always been 14.5 volts or there abouts,but concerned about the smoke really. 2009 Vogue SE Zermatt silver |
Cracked manifold would be cheaper than new turbos though. Every cloud lol |
It will be cheaper than turbos and is fairly common. Get some soapy water in a spray bottle take the top cover off and spray it on the plastic manifold with the engine on and maybe so done gently raving and look for bubbles. Start with the right hand one (drivers side) first I'd say.
Thanks for that kbald I'll have a look tomorrow and see what's what. Might have to use my local indy landranger services for the manifold or turbos.its been relatively trouble free for the past 5 yrs so can't complain too much. 2009 Vogue SE Zermatt silver |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 473 ![]() ![]() ![]() |
Make sure you check the hoses thoroughly, the right one as you look at the engine cracks under the webbing and you can’t see it until removed. 4 years depending on mileage would be about right for them to fail again, I only got 3 years but did do a lot of towing. |
Thanks diesel dave,I'll have a look tomorrow. 2009 Vogue SE Zermatt silver |
Pulled the top intercooler pipes off and found a 1inch split in the pipe with the webbing on it,ordered 2 new ones which will be here in the morning.
That's worked out well. Much cheaper than a manifold or turbos Current 2007 TDV8 Vogue Buckingham Blue |
Have to say it's made my day...I'll fit the new hoses tomorrow then fingers crossed all will be well |
Fantastic to hear, hope all is ok now |
All is well now thanks,new hoses fitted fault codes cleared and just been on a quick run and car feels perfect again. |
Just a quick update about my new turbo hoses,they have been fitted a week now so i pulled them off to see what they were like inside after a weeks running,the left hand one looking from the front does have a film of oil on the inside of the hose,is this normal do you think?while the right hand one is dry(the right hand one is the hose that had the split)my egr valves were replaced 20000 miles ago and they are working fine so i was thinking of doing the egr blank and the thought behind this is it should help avoid turbo problems in the future. Anyone agree or not? 2009 Vogue SE Zermatt silver |
