Home > Technical (L322) > Front suspension question |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8306 |
Never heard of that myself, I imagine it wasn't done properly the first time... Pete
1st Jul 2020 8:03pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Yes I think as you Pete.
1st Jul 2020 9:15pm |
Can't think of anything obvious... Pete
1st Jul 2020 9:28pm |
Thanks mate. 2010 3.6tdv8 180k km.
1st Jul 2020 11:56pm |
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 |
If the suspension control arms were removed, or their respective bushes unbolted / loosened from the subframe, and then not torqued back down properly and in the correct rotational position on reassembly , I imagine that the bush inner tube/sleeve could be "letting go " under load and rotating inside the subframe mounting point, in essence the entire bush is rotating around the bolt holding it in place..?? |
2nd Jul 2020 6:11am |
I think u cannot connect wrong because there is a pivot point.
2nd Jul 2020 10:55am |
You can connect wrong..
2nd Jul 2020 11:05am |
Will fınd out tomorrow since front sank just now.
2nd Jul 2020 1:50pm |
I am sorry but I did not understand last tip-swaybar clearing everything?? What should I check?? 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
2nd Jul 2020 2:29pm |
Hi again
7th Jul 2020 11:03am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
The compressor getting hot and cutting out means you probably have an air leak. From what you describe I think it may be the front left strutt. It is probably not leaking normally only when you go over a bump or when in extended mode.
7th Jul 2020 4:45pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Mine had that sort of behaviour, the airbag had cracked where it folds and flexes, it only leaked in certain positions. The downside was I was travelling back from Northern Ireland so I kept resetting the suspension error to get me home. If I drove above 50 mph it was fine, no issues (does the suspension lower at higher speeds?), if I slowed down the compressor would start to work overtime. I replaced the bags and the compressor and it was fine, great system IMHO. BMW i3 Electric Car
7th Jul 2020 4:50pm |
Yes definitely from left one. It was making noise when lifted after bag change. Car is 165k km now. After change of struts about 150km done. We sprayed soap when car was on lift and suspension was fully extended. We did not see any bubbles. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
7th Jul 2020 9:00pm |
U can have this problem it is normal. My problem is with newly repaired bags. What could cause the new bag leak after a bump for 10 seconds. I hope this did not ruin the compressor. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
7th Jul 2020 9:02pm |
