Home > In Car Electronics (L322) > How to... Fit Android Head Unit to 2002-2005...
Page 17 of 20 <123 ... 1617 181920>
ChrisRRV
United Kingdom 2004 Range Rover Vogue 4.4 V8 Tonga Green
I'd love to maintain the logic 7 system but I hear it's a bit of a ball ache.
What did you do with both of yours?
I presume as mines DSP amped it won't work with that head unit out of the box without the bypass kit etc?
Post #559680 30th Jun 2020 7:47pm
Danwilderspin
Ahh sorry yours is dsp not logic 7?
Well I went the whole hog and ripped out the amp on my dsp setup but about a month later ibus app came out which you install on an android head unit around £30 and you need a usb resler interface. You can then code the dsp amp to work with a non ibus headunit. Loads have done it on the x5 forums. I’d do that.
On my logic 7 I bought a HUR box it cost £130 and it converts the line level outs from the head unit to optical for the amp.
 Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #559684 30th Jun 2020 8:02pm
ChrisRRV
Sorry I'm HK logic 7
So can I go the same way as yourself only instead of ripping amp out can I use that app?
Any steps on how to achieve this?
That looks great 👍
Post #559685 30th Jun 2020 8:04pm
Danwilderspin
I’m Confused I didn’t rip the amp out on logic 7 I did that on dsp on logic 7 I used a hur adapter.
Can I confirm the hi amp you have had the orange optical lead in the boost as they did a non optical hk amp too and don’t want to talk at cross purposes Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #559686 30th Jun 2020 8:06pm
ChrisRRV
Sorry my fault on the confusion it's been a long day lol
Yes I'll check this tomorrow
I've the HK logic 7 but I will check that info tomorrow and report back
So of I have the logic 7 amped via optical lead is that the bypass wiring needed?
If it's not optical then I can use that Hur adaptor
Thanks
Chris
Post #559687 30th Jun 2020 8:08pm
Danwilderspin
No other way around - if it is optical you do need hur if it’s not I think you can wire directly in Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #559697 30th Jun 2020 8:51pm
ChrisRRV
Anyone any pics of the wiring to tell whether I have the optical connected HK system
Post #560059 3rd Jul 2020 9:17am
ChrisRRV
Got bad news on my unit its a MY05 MOST range
So whats my options is the question Sad
Post #560476 7th Jul 2020 11:09am
Weegie
Your MOST system is the same as in Dan's 2007 with Logic 7, so you could probably go down the route he has taken. John
GAP iiD BT
Post #560477 7th Jul 2020 11:20am
ChrisRRV
@Danwilderspin do you have a link to the HUR box you bought
Post #560480 7th Jul 2020 11:34am
Danwilderspin
https://avinusa.com/most-fiber-optic-amp-i...ander.html
Here you go there is one problem with it I feel I should tell you. It works by setting the amps volume to 100% so if there’s no music and the car is off you can slightly here a hiss of amplifying nothing with the car idling and driving I don’t hear it and with something playing I definitely don’t. Just being honest. It’s annoying as if they set the amp to say 80% it would be fine.
The other option is to gut it and use aftermarket amp Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #560481 7th Jul 2020 11:41am
ChrisRRV
Thanks alot Dan ill get one ordered up to go with the same Erisin unit you went for
Post #560489 7th Jul 2020 12:29pm
ChrisRRV
Dan one final thing did you need a fasica unit for your erisin unit? Or does it fit perfectly?
Post #560490 7th Jul 2020 12:36pm
Danwilderspin
Hi Chris - the Erisin I have is different to that one (mine is a year old now and they churn these out quick) mine had the traditional CD player backing to it as opposed to the tablet style. Mine in the 2002-05 went in fine there is a a massive cavity behind it but if it’s loads thicker you may need to get a bit handy with how you mount it. I didn’t need anything else tbf I bought a 5m most cable as I’m lazy and couldn’t be bothered to reroute what was there I think it was about £20 from Ali express Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #560495 7th Jul 2020 1:13pm
Danwilderspin
Just remember you won’t be able to set the clock as this is set through the screen unless you buy a resler interface and a licence of ibus app.
Completely untested on the most setup with a 4.4 but as everything else is Bmw still and it still retains an ibus network I think it should work fine if you want to try it I know a guy selling a resler interface (me Smile ) pm me - you can trial the app to see if it works before buying it . Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #560496 7th Jul 2020 1:18pm
