Home > Technical (L322) > Headlight assembly part numbers
Ben0148
United Kingdom 2009 Range Rover Vogue SE TDV8 Java Black
Hi all,
only recently purchased my Range Rover it’s a 2009 tdv8 but the front near side headlight has a small crack which is causing water ingress, I’ve been searching for a replacement unit but I’m slightly baffled by the range of part numbers for a front headlight!
My current headlight part number is 6h4213w030da8lpo
Is this the only headlight unit that will work with the car or are there other part numbers I could fit from a similar year?
I know the unit is a xenon but having a bit of trouble understanding what the rest of the differences between the units are and if I could buy another part number of head light ( the only one matching that part number available is in the Czech Republic!)
Thanks in advance!
Ben
Post #559661 30th Jun 2020 6:37pm
