Home > My Range Rover > Long time Land Rover owner, now Range Rover owner |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Welcome! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Jun 2020 8:42pm |
Shane48 Member Since: 27 Jun 2020 Location: Bungay Posts: 9 |
Yeah that’s least of my worry’s at the minute on 165k at the minute but to be fair the box feels really good but time will tel |
27th Jun 2020 8:43pm |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 |
Hi Shane,
28th Jun 2020 8:06am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 454 |
Hi Shane. Nice looking motor and welcome to the best collection of enthusiasts and knowledge you’ll find anywhere. I’ve had a couple of l322’s with similar mileage to yours and as long as they’re looked after it doesn’t seem to bother them. The Td6 is pretty much a bullet proof engine, just make sure the transmission oil has been changed recently and if not do it ASAP as that was the weak point on the TD6. Other than that I just found the usual things like brakes and suspension needed attention, but if you’ve been a mechanic it shouldn’t turn out too costly. Enjoy |
28th Jun 2020 8:38am |
Thank you! Seems ok so far, gearbox oil is on order as no history on that unfortunately but that was reflected in the price I paid. There is a few other bits I’m working through at the minute, needs a wheel bearing a window switch and a few other bits. Hopefully this new relationship won’t be to painful |
28th Jun 2020 8:44am |
Blank off the EGR would be my first job
Already on order! Felt a little sluggish, had codes for egr and boost control solenoid but I found a couple of vacuum pipes off and split under the bonnet but the egr will be going regardless |
28th Jun 2020 8:47am |
