Home > Maintenance & Mods (L405) > Deployable Towbar Module
Tom_T
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
I've got a query regarding the deployable towbar module on my FF, and hopefully you guys will be able to assist:
I believe that my control module is faulty, as it emits the warning tone to suggest that the towbar is not fully deployed/stowed, even though it is fully stowed. Now, I believe that there was a recall for this a few years back however i'm unsure if mine ever had the recall work carried out.
The module which I currently have installed has the part number: CPLA 19H397-AG
My question is this: should i replace my module with an identical one, or should i replace it with the module which has the part number CPLA 19H397-AF
I'm wondering if the module with the AF part number was the one installed as part of the recall? Or perhaps as G follows F alphabetically, then I may already have the newer version of the control module, and mine is just a faulty one Confused
If anyone could shed some light it would be appreciated, I don't want to replace the control module with one which is liable to go wrong in the future!
Thanks
For reference this is the control module installed in my car.
Post #558946 25th Jun 2020 8:13am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
AG is the latest one - the ones with issues are AE and some of AF (module serial numbers between #26747 to #48666) so you have the latest module
You may just need to reinitialise the module if the towball is moving but not locking.
Start engine and run for longer than 2 seconds. Stop engine. Switch ignition to ON. Switch ignition to OFF
Press the 'Activate' button (the left side switch on the deployable towbar switchpack) for 2 seconds until the green LED illuminates on the 'Deploy/Stow' button
Press 'deploy/stow' button and hold until towbar reaches its fully deployed position. During deployment the buzzer will pulse as a warning. During deployment the green indicator will flash as a warning. At the end of deployment the towbar will give a beep/beep sound
Release the 'Deploy/Stow' button
There is quite a detailed troubleshooting guide in the Workshop manual (in the wiki) for the towbar including reference to what the various beeps and flashing LEDS on the switchpack mean. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #558967 25th Jun 2020 11:58am
Tom_T
That's great. Thanks nicksaab for the info Thumbs Up
Post #559079 26th Jun 2020 7:46am
