![]() | Home > Maintenance & Mods (L322) > L322 Battery going flat. |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Last night there appeared to be an intermittent 2A discharge & the sound of a fan (smaller than the main blower & larger than the tiny dashboard one that senses the cabin temperature.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
No experience of that model, but when my 2012 WM had battery drain the problem the first time was fuel burning heater software and the second time locking software. The car went off to the dealer (still under warranty) and they ran a diagnostic check to find the problem. They also recharged the battery fully and tested its capacity to hold charge in future. The first battery (aged under a year) was finished and replaced under warranty, the second was OK and worked fine until I traded the car in. I was told the battery had to be fully charged for that test to be done/possible.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Try disconnecting your FBH (Fuel Burning Heater), see if the fan noise goes away .
I've pulled fuse # 59 <auxiliary> already - is there anywhere else to disconnect it please ? 2003 Range Rover Vogue TD6 |
That is it. (other than disconnecting the wires!)
I'm almost certain it's the main heater fan - you can hear it from under the bonnet towards the bulkhead & from inside the cabin. 2003 Range Rover Vogue TD6 |
Hmmm, does smack of FSR......
Tried the other FSR & invested in a new genuine LR one,
The new battery was replaced by an identical one, apparently, I now now regarded as a "budget" one.
After one garage (with ex:Landrover Master Tecnician failed to find the cause Discovery Garage at Whitstable found that the circuits on fuse 27 were the culprit not allowing the vehicle go to sleep.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Good stuff glad its sorted |
Sharpy1980 Member Since: 20 Nov 2016 Location: Kent Posts: 55 ![]() ![]() ![]() |
I had a customer bring me there FF a couple of years ago after spending a lot of money in various garages trying to find a battery drain, I traced it to a certain fuse that wouldn’t let the car sleep properly but instead of a bypass I was asked to carry on and I found a very well hidden tracker that the internal battery backup had failed so the car’s battery was trying to charge it continually, the best part is they had owned the car from virtually new and had no idea it even had a tracker. L322 4.4 TDV8 Current
muddycharles Member Since: 05 May 2011 Location: Miami, FL Posts: 90 ![]() ![]() ![]() |
I had the glovebox light fail, and replaced it (did not know there was a light until this forum enlightenment me). However what if the glovebox light stays on? Have you looked at the swith for that? 2008 HSE B. Grey
