Home > Technical (L322) > Restricted Performance L322 2011 4.4 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
yes you can douse the CSOV Ian.
21st Jun 2020 9:16am |
Ianclark1275 Member Since: 11 Apr 2020 Location: York Posts: 67 |
Thanks for the reply,
21st Jun 2020 12:27pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
I called out LR Assist the first time mine through up R.P. alarm and he diagnosed it from the fault code.
21st Jun 2020 1:40pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Ian - looks like yours has the nut still on the CSOV. Needs the modification but get codes read first as it might be something else Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
21st Jun 2020 1:54pm |
PS Use JAS Land Rover nr York. One of the best independents in your neck of the woods Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
21st Jun 2020 1:55pm |
Thanks all, i will get codes read,
21st Jun 2020 2:19pm |
21st Jun 2020 8:59pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
That actuator rod, can it be manually moved & at the same time a dollop of WD40?
21st Jun 2020 9:12pm |
I tried with hand but couldn’t reach
21st Jun 2020 9:51pm |
25th Jun 2020 7:30pm |
Codes are listed in a section of the workshop manual in the wiki
25th Jun 2020 7:45pm |
Thanks buddy
25th Jun 2020 10:06pm |
