Home > Technical (L322) > Restricted Performance L322 2011 4.4
Ianclark1275
Morning guys
Day 21 of RR ownership
Went from York to South Shields yesterday and on the way there got restricted performance (after 30 mins of cruise control 70mph)
I have a “start engine low battery” after maybe 30 secs of ign on since I bought it
Health check from an Indy garage last week.
Had look through forum and can see the cSOV actuator is a close symptom match
it has some new manifold hoses, and I had a look at top inter cooler hose
Gapid tool on order....
Oh, after beach it was fine and has been ever since !!
Can I dribble WD40 onto the cSOV valve ?
Thanks
IC
Post #558444 21st Jun 2020 9:04am
GGDR
yes you can douse the CSOV Ian.
You can also give give it a turn back & forth by hand.
and you can also get a vacuum test hand tool and test it's vacuum operation.
But the first two are fine.
95% or restricted issues on the 4.4TDV8 are down to air system leaks.
search 'restricted 4.4TDV8' - plenty have had these issues and solved them.
. Cheers, Greg
Post #558445 21st Jun 2020 9:16am
Ianclark1275
Thanks for the reply,
I can hear the turbos hissing when i lift off throttle.
Post #558462 21st Jun 2020 12:27pm
Baltic Blue
I called out LR Assist the first time mine through up R.P. alarm and he diagnosed it from the fault code.
His first attempt was to give it a good squirt of WD 40 to free it, but it failed again as soon as I got to 2500rpm, so he booked it in at the MD and they changed it for the later “no nut “ modified type.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #558468 21st Jun 2020 1:40pm
DrRob
Ian - looks like yours has the nut still on the CSOV. Needs the modification but get codes read first as it might be something else Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558470 21st Jun 2020 1:54pm
DrRob
PS Use JAS Land Rover nr York. One of the best independents in your neck of the woods Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #558471 21st Jun 2020 1:55pm
Ianclark1275
Thanks all, i will get codes read,
Yes, spoke to lady at Jaś - and promised i would call in with Repairs when they occur!
Post #558474 21st Jun 2020 2:19pm
Ianclark1275
Got some WD40 on it
Intercooler pipe was a bit oily ?
Post #558542 21st Jun 2020 8:59pm
Fox889
That actuator rod, can it be manually moved & at the same time a dollop of WD40?
Mines going in Tuesday as RP flagged up twice now when reaching 3000rpm, Indy read the code which pointed towards the second turbo actuator, we'll see. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #558547 21st Jun 2020 9:12pm
Ianclark1275
I tried with hand but couldn’t reach
I’m not near my tools currently so couldn’t get at it easily
Post #558555 21st Jun 2020 9:51pm
Ianclark1275
U040568 invalid data received from speed control module
That was the time and date of the RP last Sunday
Anyone know what it is ?
Thanks
IC
Post #559031 25th Jun 2020 7:30pm
DrRob
Codes are listed in a section of the workshop manual in the wiki Thumbs Up
Scroll down to bottom Thumbs Up
https://www.fullfatrr.com/wiki/Main_Page Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #559036 25th Jun 2020 7:45pm
Ianclark1275
Thanks buddy
It’s says cruise control fault
It makes sense as I press “set” sometimes and nothing happens - press it again and it works
I will change the battery and see how it goes...
Check Speed Control Module for related DTCs and refer to relevant DTC index
Refer to the electrical circuit diagrams and check the power supply and ground connections to the Speed Control Module
Using the manufacturer approved diagnostic system carry out network integrity tests. Refer to electrical circuit diagrams and check CAN circuits if required. Repair wiring as required
If no wiring or network faults found suspect Speed Control Module, Refer to the Warranty Policy and Procedures manual, or determine if any prior approval programme is in operation, prior to the installation of a new module/component
Post #559058 25th Jun 2020 10:06pm
