![]() | Home > Range Rover P38 > 15mph judder |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Milage?
WellDrivenJames Member Since: 03 Feb 2020 Location: Cambridgeshire Posts: 44 ![]() ![]() ![]() |
Mileage is 135k, no vibration at idle or speeds below 15mph. It kicks in around 15 and then stops again at about 20mph, regardless of gear/revs - I'll try locking it in 1st and see if that's any different.
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 ![]() ![]() ![]() |
I’ll probably get shot because this relates to an L322 not a P38..........but Just in case it proves helpful, I had a judder between about 15mph and 25mph. Everybody said “classic torque converter break up”. One gearbox refurbish and new torque converter later. The judder was unchanged. Then PCourtnay on here said check the rear prop shaft centre bearing carrier. Which proved to be the culprit.
Milage is moderate, what sort of transmission servicing has it had
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 965 ![]() ![]() |
Seriously guys hold on a minute you dont even know what engine it has in it
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 187 ![]() ![]() |
/\ what he said! |
Apologies, it’s a ‘96 auto derv. |
I was assuming the profile picture suggested a P38 |
I managed to test it a bit more today - wobble kicks in at about 15-20mph where it is at its worst, then gets better as speed increases and then it’s gone above 50mph.
Yes he says p38 in his post but now we know the engine and drive train it's a big help.
Turns out it was the propshaft UJs - all replaced now and going to pick it up this afternoon.
