Home > Range Rover P38 > 15mph judder |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Milage?
5th Jun 2020 8:48pm |
WellDrivenJames Member Since: 03 Feb 2020 Location: Cambridgeshire Posts: 44 |
Mileage is 135k, no vibration at idle or speeds below 15mph. It kicks in around 15 and then stops again at about 20mph, regardless of gear/revs - I'll try locking it in 1st and see if that's any different.
6th Jun 2020 8:18am |
TomV8 Member Since: 25 Sep 2017 Location: Yorkshire Posts: 107 |
I’ll probably get shot because this relates to an L322 not a P38..........but Just in case it proves helpful, I had a judder between about 15mph and 25mph. Everybody said “classic torque converter break up”. One gearbox refurbish and new torque converter later. The judder was unchanged. Then PCourtnay on here said check the rear prop shaft centre bearing carrier. Which proved to be the culprit.
6th Jun 2020 8:52am |
Milage is moderate, what sort of transmission servicing has it had
6th Jun 2020 10:13am |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 918 |
Seriously guys hold on a minute you dont even know what engine it has in it
6th Jun 2020 11:03am |
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 186 |
/\ what he said! |
6th Jun 2020 4:37pm |
Apologies, it’s a ‘96 auto derv. |
6th Jun 2020 6:32pm |
I was assuming the profile picture suggested a P38 |
6th Jun 2020 8:52pm |
I managed to test it a bit more today - wobble kicks in at about 15-20mph where it is at its worst, then gets better as speed increases and then it’s gone above 50mph.
7th Jun 2020 4:27pm |
Yes he says p38 in his post but now we know the engine and drive train it's a big help.
7th Jun 2020 4:42pm |
Turns out it was the propshaft UJs - all replaced now and going to pick it up this afternoon.
19th Jun 2020 10:24am |
