![]() | Home > Technical (L322) > Air suspension |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
I could be wrong but it seems to me that the compressor has worked too hard/overheating - see what happens when it's had time to cool off. 2003 Range Rover Vogue TD6 |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
That is indeed the reason. The pump is thermally overloaded. You either have a leak somewhere in your system which is resulting in your pump running too often or you have something wrong with the pump itself.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Check you dont have a leaking suspension airbag. BMW i3 Electric Car
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
Put the car in off road height, turn the engine off, leave a door open so the suspension doesn't level and listen to the wheel wells, you should be able to hear the leak.. if you can't then disconnect the battery and see if the car drops overnight, if it doesn't then take a look at your pump.. Pete
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Pumps? AMK recommended by JLR. Hitachi was fitted by JLR, Dunlop very cheap easy to repair check U-tube |
