![]() | Home > Technical (L322) > DPF failure to regenerate - AGAIN!! (AND AGAIN!! UPDATE) |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3200 ![]() ![]() |
Then this evening's figures!!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4326 ![]() ![]() ![]() |
Have you checked (again) the usual inlet suspects? The throttle body seems to be emerging as another one. I'm told by an ex LR mechanic that the seal and spring wear with age. There's a couple of threads on it as you probably know. Perhaps look at it for soot, looseness and fit? Perhaps try the PTFE trick?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Shame your issues have returned Dolphin
Take off the throttle body plastic pipe and see if its oily and sooty underneath on the OUTSIDE of it. Or get a white tissue and wipe underneath it in situ as a first test Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Hi chaps, thanks yes will do all those things you suggest.
Any fault codes stored? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
none (just like when it went red). |
Right, haven't had a chance to get a clear look under the bonnet due to weather (torrential) and time (scarce).
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 331 ![]() ![]() |
Hi DB.
Lost a few posts here....?
@RRL322, I think you may be right. It was trying to regen but was being hindered. It may be an EGR temp sensor fault not allowing the exhaust to get hot enough to regenerate.
I think in this instance it's a main dealer plug in and assess jobby |
rob, Sensor was changed 1000 miles ago (if you mean the rear DPF sensor). Or do you mean the EGR temp sensor?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35528 ![]() ![]() |
Craig is only up the road from you , can he not sort it.. ... - .- -.
