Home > Maintenance & Mods (L405) > Towbar paint removal?
madasmad
United Kingdom 2019 Range Rover Autobiography SDV8 Baltic Blue
Hi, my, new to me, FF has a factory fit electrically deploy able towbar that doesn’t look like it has ever been used. It is black in colour and I assume painted? On previous cars when I have had towbars fitted I have always removed the paint prior to use so not to contaminate the hitch pads. Once not in use I would then put on a cover to stop the tow ball corroding. My question is should I remove the black surface treatment and if so how do I stop corrosion as in the handbook it states not to put a cover on the tow ball?
Thanks 2019 Autobiography SDV8 Byron blue/black - current
2016 Vogue SE SDV8 Santorini Black/Ivory - sold
2009 RR Sport TDV8 HSE - sold
Post #557981 17th Jun 2020 9:06am
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Had this same issue with two new cars.
JLR say leave it on Alko (caravan chassis maker) are very non comital.
So I always remove the paint then I have control over what contamination if any gets on the stabiliser pads.
Had no issues over the many years I have been towing adopting this method. 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #557997 17th Jun 2020 11:29am
madasmad
Thanks Palli,
Do you leave the tow ball uncovered as the handbook says, and, if not, does it corrode? 2019 Autobiography SDV8 Byron blue/black - current
Post #557998 17th Jun 2020 11:33am
palli
Since mine is deployable it is not possible to leave covered when stowed. So a wipe with a clean cloth before hitching up clears any surface rust etc. 2008 Vogue Black - gone
Post #558045 17th Jun 2020 5:12pm
Yes. Always clean off the paint with some sandpaper or emery cloth.
It does depend on what you tow though.
If you aren’t towing something with a stabiliser hitch then it doesn’t really matter too
Much. But if you have an Alko type hitch then yes. It will contaminate the pads on the stabiliser. There is nothing that can't be fixed with a hammer😜😜
Post #558047 17th Jun 2020 5:23pm
madasmad
Thanks guys👍 2019 Autobiography SDV8 Byron blue/black - current
Post #558050 17th Jun 2020 6:06pm
