![]() | Home > Technical (L322) > Towbar compatibility |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8749 ![]() ![]() ![]() |
Not straight bolt on.
Neilacker Member Since: 02 Mar 2020 Location: Haydock island Posts: 21 ![]() ![]() |
I have just done this, when I removed the original brackets from underneath they have the exhaust hangers on them that you need, I just got a grinder on the weld then put them on the new tow bar frame job done |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I'm just about to do this too. I have cut the bits off a spare pair of brackets and will bolt them onto the older armature arms.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35629 ![]() ![]() |
this any help,
Perfect. Thanks Stan. 2010 4.4 TDV8 Vogue SE |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Those are the bits you need to cut off of the exiting strengtheners Current: 2011 FFRR Vogue SE 4.4 TDV8 Previous: - 2004 FFRR Vogue 4.4 V8 with LPG 1997 P38 4.0 SE with LPG 1997 P38 4.6 Vogue with LPG |
