Home > Technical (L322) > Towbar compatibility
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
I suspect the answer is no but does a factory fit westfalia towbar from a 2004 car fit a 2010? 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #557688 14th Jun 2020 3:49pm
Not straight bolt on.
There is some bracketry difference for the exhaust hangers afaik. The rest of it will be pretty much the same. There is nothing that can't be fixed with a hammer😜😜
Post #557689 14th Jun 2020 3:59pm
Neilacker
I have just done this, when I removed the original brackets from underneath they have the exhaust hangers on them that you need, I just got a grinder on the weld then put them on the new tow bar frame job done Very Happy 2010 tdv8 vogue se, Buckingham Blue
Post #557696 14th Jun 2020 5:49pm
kooky_guy
I'm just about to do this too. I have cut the bits off a spare pair of brackets and will bolt them onto the older armature arms.
Just trying to collect as much information as possible before I physically start pulling it apart. Shame the photos have all gone from the wiki article.
Anyone know where I can find the official LR instructions? The link to those in the wiki doesn't work either. 2010 4.4 TDV8 Vogue SE
Post #557782 15th Jun 2020 11:23am
this any help,
https://www.fullfatrr.com/gallery/albums/u...40_vr1.pdf ... - .- -.
Post #557784 15th Jun 2020 11:30am
kooky_guy
Perfect. Thanks Stan. 2010 4.4 TDV8 Vogue SE
Post #557796 15th Jun 2020 12:33pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Those are the bits you need to cut off of the exiting strengtheners Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #557800 15th Jun 2020 12:57pm
