Home > Technical (L322) > Airbag gone. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
I did bags only on my 2012, a little over an hour for the first one and under an hour for the seconds one. Easy job, assistance is needed when lifting it back into place (well I needed assistance). Just make sure the seal areas are clean, all perfect after I'd done it.
13th Jun 2020 6:30pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
Thanks AJ. I remember reading when you did them.
13th Jun 2020 6:35pm |
I found it easy, a bit of lube and they slide on no problem. I would recommend soaking all the relevant nuts and bolts with Plusgas for a couple of days prior to doing the job, mine came undone easy.
13th Jun 2020 6:46pm |
Great. Already started with the plusgas.
13th Jun 2020 6:48pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
For the relatively small extra cost, it would be worth getting new bottom bolts. When I did mine on the Td6 the bottom bolts took a bit of a hammering, despite soaking them. John
13th Jun 2020 6:53pm |
Did think that. I agree. 2011 4.4tdv8 Vogue
13th Jun 2020 6:55pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Do both sides, full strut exchange, peace of mind .
13th Jun 2020 7:01pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
I had exactly the same earlier this year on my 2011 5.0 S/C, and replaced both struts complete from Island 4x4, as I wanted to make sure it returned to full reliable service, and there were no further air leaks.
13th Jun 2020 8:01pm |
2011 4.4tdv8 Vogue
13th Jun 2020 8:10pm |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
At what mileage do bags tend to go? Mine's coming up to 75000 now and still on originals AFAIK. Previous cars:
13th Jun 2020 8:39pm |
I think it's probably a combination of mileage and age.
13th Jun 2020 8:48pm |
Well I have just tipped the 102 or nearly 103k now.
13th Jun 2020 8:54pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Whatever you choose to do make sure you do both sides sir... |
13th Jun 2020 11:04pm |
Definitely both sides, totally agree.
14th Jun 2020 4:50am |
