![]() | Home > Technical (L322) > Airbag gone. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I did bags only on my 2012, a little over an hour for the first one and under an hour for the seconds one. Easy job, assistance is needed when lifting it back into place (well I needed assistance). Just make sure the seal areas are clean, all perfect after I'd done it.
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
Thanks AJ. I remember reading when you did them.
I found it easy, a bit of lube and they slide on no problem. I would recommend soaking all the relevant nuts and bolts with Plusgas for a couple of days prior to doing the job, mine came undone easy.
Great. Already started with the plusgas.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
For the relatively small extra cost, it would be worth getting new bottom bolts. When I did mine on the Td6 the bottom bolts took a bit of a hammering, despite soaking them. John
Did think that. I agree. 2011 4.4tdv8 Vogue
Do both sides, full strut exchange, peace of mind .
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 ![]() ![]() ![]() |
I had exactly the same earlier this year on my 2011 5.0 S/C, and replaced both struts complete from Island 4x4, as I wanted to make sure it returned to full reliable service, and there were no further air leaks.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
At what mileage do bags tend to go? Mine's coming up to 75000 now and still on originals AFAIK. Previous cars:
I think it's probably a combination of mileage and age.
Well I have just tipped the 102 or nearly 103k now.
Whatever you choose to do make sure you do both sides sir... |
Definitely both sides, totally agree.
