Home > Technical (L322) > 4.2 SC lean codes |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
i havent since its been rebuilt. but i guess worth doing one jic. |
12th Jun 2020 12:49pm |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
I would hope so, but was helping a friend recently with is jag 4.2 that has valves redone and we found a leak on one of the splark plugs due to a badly cut thread |
12th Jun 2020 1:49pm |
ive bit the bullet and ordered a gap tool. next up will be replacing all the plugs because am not sure they have been for a while |
12th Jun 2020 1:51pm |
7th cylinder, am guessing cylinder closest to passenger seat. the ignition coil boot is stuck in the actual plug. i cant get the plug out, fml.
13th Jun 2020 4:57pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Is that since changing the plugs and the rest of the coils? The lpg probably needs re calibrating it would have been fitted with partially worn valves this won’t be the case now.
14th Jun 2020 1:15pm |
well the rich codes have gone away. back to the standard 1 lean code on bank 1.
It has been a few times. I think the issue is because the petrol isn't running right then calibrating the lpg to the petrol won't work well. Hmm then cylinder 8 is where am , ive also got bank 1-2 mixed up if your diagram is right. I guess the issue is in cylinder 8 so theres not much room to get anything in there. Getting the coil out was a nightmare to start with. I think we can safely conclude its not the spark plugs. time to get the air sensors done |
14th Jun 2020 7:24pm |
I’d just do the air genuine denso and genuine denso o2 sensors upstream that pairing made the world of different to mine once i concluded with a smoke test there were no leaks - have you smoke tested recently? I have ordered some downstream sensors now as preventative maintenance as if the fronts were bad I imagine they arent the best Current stable:
15th Jun 2020 7:07am |
Last smoke test was a few months ago. I know my valve cover gasket is leaking or something is leaking oil near front of engine but has never shown up in smoke test. Might be time to get that addressed as well |
15th Jun 2020 7:53am |
shameless bump So the air sensors have arrived. i havent had time to fit them yet but i havent driven the car on purely petrol for a while. so i did so today. i noticed it was correcting super hard, am guessing my LPG needs resetting up, but thatll happen anyway because am swapping the Reducer and Injectors.
17th Jun 2020 2:58pm |
What air sensors are you on about there is only one maf? Or are you including the o2 as well? Check the date on the maf if it’s original just change it or if it’s not denso Current stable:
17th Jun 2020 3:25pm |
ive gotta stop being an idiot and calling it an air sensor Lambda sensor is what i mean.
17th Jun 2020 3:26pm |
I’d just do them unless you get under there and they looks fairly recent if you don’t do them now and they are original they will prob need doing them in the not too distant future... I’m guessing there were only £100ish for the pair anyway it would be good preventative maintenance if nothing else Current stable:
17th Jun 2020 3:31pm |
for now am just trying to get to an equilibrium. plus i wanna know exactly what fixed it. so if i add them now am not gonna know if its them or the plugs. with the plugs Ill need 1 new coil as well for the one with the broken boot
17th Jun 2020 3:32pm |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
I've had a similar "Lean on Bank" issue recently.
17th Jun 2020 3:48pm |
