Home > General > Buying a 4.2 sc vogue |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Depends on what other work was done and also when the miles were put on it and of course the price |
11th Jun 2020 3:25pm |
Prits2104 Member Since: 11 Jun 2020 Location: Manchester Posts: 10 |
Its had new brakes all round last year, new air suspension redone 3 or 4 years ago, new suspension bushes rear last year. Problems: rev cam doesnt work properly, as far as I know it would need a new camera that I've seen ebay upgrades
11th Jun 2020 3:42pm |
It's on 120k miles, 9k miles in owners last 2 years owning |
11th Jun 2020 3:43pm |
I would be more worried about the fact it has only done 9k in last couple of years mine is same age and is on 190+ but I do lots off work on it reckon about 2 to 3k a year including tyts but I do 20 odd k a year so. It should be ok I reckon if cheap enough |
11th Jun 2020 3:56pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 890 |
I dont see a problem with it the tv is only meant to work when stationary, reverse camera a ÂŁ5 part |
11th Jun 2020 3:59pm |
I thought the tv would work whilst moving in the back? |
12th Jun 2020 8:52am |
You can probably have the tv on In the back whilst moving, but the signal will likely drop in and out. The system was primarily designed for TVs in houses, which tend to be stationary, unless something bad is happening....
12th Jun 2020 10:37am |
đ¤Łđ¤Łđ fair play mate.
12th Jun 2020 11:26am |
You could of course have a specific issue with the tv in that car, but even when itâs working, signal drops in and out. You ought to get a signal somewhere, so try retuning when stationary on the test drive.
12th Jun 2020 11:33am |
I'm not sure but it might need diff oil doing? Also does the Supercharger oil need to be changed?
12th Jun 2020 1:28pm |
Diff oil:
12th Jun 2020 2:18pm |
