![]() | Home > In Car Electronics (L322) > 2011 Dual View Screen Upgrade |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Anyone upgraded to dual view screen?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16333 ![]() ![]() ![]() |
No sir... They are coded to the VIN... |
What hardware can recode?
I’ve no idea! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35597 ![]() ![]() |
its a gimmick and i dont think anyone uses the dual view...if you are thinking of watching tv on the move you'll be very disappointed as the signal fluctuates greatly... ... - .- -.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
.......... but it does allow DVD to be watched on the move........ Current: 2011 FFRR Vogue SE 4.4 TDV8
yes but only if you have RSE. ... - .- -.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Agreed. I listen to BBC News as I'm driving (no video obviously) and it gets annoying when it drops out. I would be focussing more on the mechanical "health" of a future purchase and not fancy ICE ![]() e.g. if looking at a TDV8 then has it had turbo drain mod for exhaust "cloud" on booting? Is the oil cooler leaking? They all "go" at higher mileage. Has the gearbox oil been changed? The list is endless: 4th post down: https://www.fullfatrr.com/forum/topic44115-75.html ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
I think it depends massively where you are, and what speed you're doing. On my standard (pre-COVID) drive London -> Poole, for the hour crawling through central London it works beautifully, so my wife gets to watch at least 1 hour of something (Escape to the Country normally). And then as soon as we hit the M3 and speed up, it becomes intermittent, and so we switch to the DAB radio. But if you spend lots of time crawling through traffic-jammed cities and towns, it might actually have a use! |
fair point |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
quite fitting watching escape to the country while on a journey escaping to the country!
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
This would likely be an easier solution?
