Update:
The LR-garage says this message can mean 3 issues:
- defect (broken) oil-pressure-sensor-cable
(the cable goes through the oil-pan. And if broken at some point (which is often the case, so my LR dealer) then a „short“ is the result- and an error message
- defect valve cover gasket
- defect (not 100%) bypass valve
All of this wouldn‘t produce a yellow or red warning light in the Dashboard necessarily
Most likely in my case would be first scenario (oil-pressure-sensor-cable). Will look for that in January or February.
