Home > Technical (L322) > P00CF-62 (2F) barometric pressure boost sensor A correlation
flashgordon
Germany
Engine: 4.4 TDV8 2011
since a while I get the error message:
Could this be related to a missing „Synchronisation“ of the 2 new turbos that I have???
It seems my IID tool can not delete this error message.
Post #537725 17th Dec 2019 6:58pm
flashgordon
Germany
Update:
The LR-garage says this message can mean 3 issues:
- defect (broken) oil-pressure-sensor-cable
(the cable goes through the oil-pan. And if broken at some point (which is often the case, so my LR dealer) then a „short“ is the result- and an error message
- defect valve cover gasket
- defect (not 100%) bypass valve
All of this wouldn‘t produce a yellow or red warning light in the Dashboard necessarily
Most likely in my case would be first scenario (oil-pressure-sensor-cable). Will look for that in January or February.
Post #538077 21st Dec 2019 7:50am
Corsica
France 2011 Range Rover HSE TDV8 Santorini Black
Hello, do you have a follow-up to this post because I have the same problem thank you
Post #556206 2nd Jun 2020 7:01am
flashgordon
Germany
no, no follow up so far
I was told maybe an air leak somewhere and the mechanic thinks he can hear a typical "turbo" blow/whistle noise at strong acceleration…
but it seems to have no serious consequences so far ...
Post #556219 2nd Jun 2020 10:21am
