Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3183 |
You don’t necessarily need to boot it to get a RP message. If you look at some of us who have suffered similar, the RP came up when under gentle acceleration or Holding a steady rpm. Mine always occurred on the same stretch of my commute (M4) at 75 mph, just as a small demand was made on the engine at the start of a slight incline. I could almost guarantee when it would happen.
27th May 2020 3:27pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Had a quick look under the bonnet, the plastic pipe to throttle body is nice and dry but on the plenum there is clearly some oil misting to see. Would be nice to think that this is down to the oil filter cover and not the plenum itself although not hopeful. As soon as I can get the high pressure smoke test carried out I will provide further updates
27th May 2020 5:29pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Well at least I have some good news.
27th May 2020 9:25pm |
Hi Steve, that all sounds very positive, hopefully it was just those plenum pipes that were giving you the issue. 2011 TDV8 Vogue SE |
28th May 2020 7:09am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3782 |
Good news Steve
28th May 2020 12:10pm |
Hi BB
28th May 2020 1:35pm |
, I came to exactly the same conclusion over 3 years ago, .
28th May 2020 1:49pm |
Mate!!
28th May 2020 2:02pm |
All I can say is that he must be bribing the wife with treats 2011 TDV8 Vogue SE |
28th May 2020 2:51pm |
28th May 2020 10:24pm |
Quick update
30th May 2020 4:32pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
Ok let’s see how you get on there Steve.
30th May 2020 5:13pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 |
How did it pan out Steve? PTFE done the trick? Hope so Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
2nd Jun 2020 9:27am |
Hi Dr Rob
2nd Jun 2020 12:51pm |
