![]() | Home > Maintenance & Mods (L322) > Oil Change, or did they...!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8540 ![]() ![]() ![]() |
I wonder how many 5.0ltr and 4.4 diesel Full Fats have been serviced at a garage and they haven't bothered changing the oil because, apart from draining some out, there is no way to see if the oil is fresh with the demise of the dipstick from these models...
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Chap on Disco forum has worked out how to use the drain suction tube as one Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
Which engine Rob ?
Markin, the problem is getting some oil out to either look at or send for analysis, they didn't put a dipstick in these engines, they are electronically monitored...!! Pete
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
I just assume they haven't changed the oil, so one of the first things I do on any 'new' car is change the oil. At least I know it's been done and has the correct oil in it, plus if they did do it, it's now had a good flush through.
The Draper vacuum suction pump is the dogs danglies for oil changes!
V6 Disco https://www.disco4.com/forum/emergency-diy...ht=curtain Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
Pete,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
very clever |
I know that Pete will say that B.B.is a dirty diesel and his is a petrol, but , the first time I changed my oil I accidentally put in 0.25 litre too much.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Mike, you have kind of inadvertently hit the nail on the head sir... Dirty derv engined cars! The oil turns black almost immediately so, it would be very hard to check... I have a viscosity meter which works great for derv engines...
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
On the topic of clean oil in a diesel , my 3.6 used to have exceptionally clean oil after each change. I did change it every 5k kilometres but my indie always commented on how clean it was. My L322 4.4 and L405 4.4s oil have never looked anywhere as good despite the same oil change schedule. 2015 4.4 AB
As good as that may seam Dolph, my guess would be that something was wrong with your 3.6... Not that it matters to you anymore as she's gone... ![]() |
Thats interesting Camtech, as I say it was almost like fresh oil , it's still going strong as of 2 months ago so hopefully whatever was wrong with it isn't too serious |
