Home > Technical (L322) > OS/R central locking fault |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Perhaps card off and check the mechanism and all connectors and wires. No corrosion or weak spots/breaks. There's a post on here about a cable failing in the sleeve between door and body, but I can't remember if it was a lock or window fault. Try also powering the lock from a correct voltage supply. May tell you if the lock's OK and wiring/supply needs further works.
28th May 2020 2:17pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3167 |
Body Control Unit (BCU). Situated under the Pax seat. Need to remove and check/replace. Also brings about heavy steering!
28th May 2020 4:34pm |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 |
My n/s was hit and miss. I bought a replacement from Gentlemen of salvage for £19 thinking it was worth a try. All fixed and took more effort getting the door card off than anything else. 2011 4.4tdv8 Vogue
28th May 2020 6:06pm |
Myblackt5 Member Since: 27 Aug 2018 Location: Cornwall Posts: 12 |
When I lock and unlock the doors I can hear the actuator doing its thing.
30th May 2020 5:05pm |
Mine always sounded like it was working but it was too weak. It unlocked no problem if you locked by hand but rarely did it itself. On the central switch it would work more often but too hit an miss. 2011 4.4tdv8 Vogue
30th May 2020 10:22pm |
It's difficult to test, having to disconnect the battery. |
3rd Jun 2020 8:59am |
For the sake of £20 for a salvage item I would change it out. Mine moved but not enough to lock. 2011 4.4tdv8 Vogue
3rd Jun 2020 10:57am |
You make a good point, and they do have 1 for sale at the moment. |
3rd Jun 2020 11:04am |
The part arrived on Monday. Fitted it and it all works again.
10th Jun 2020 7:31pm |
Thanks for letting us know Cheers
10th Jun 2020 9:33pm |
Thank you for your help. |
10th Jun 2020 9:34pm |
was it BCU or actuator? |
10th Jun 2020 10:02pm |
Actuator |
10th Jun 2020 10:20pm |
Good news.. 2011 4.4tdv8 Vogue
10th Jun 2020 10:57pm |
