Home > In Car Electronics (L405) > Apple CarPlay retrofit by Unique AD |
W84IT Member Since: 14 Sep 2019 Location: Indio, California Posts: 43 |
Let's just use common sense...the dual view screen is not as important as the factory navigation. The factory navigation can come in handy if you happen to loose signal from your phone or actually loose your phone. The Android Aftershock unit will retain your factory navigation the same way it was before the screen upgrade. Ray
26th May 2020 10:06pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I would agree 100% on the standard nav vs the dual view. The wireless is essential in my opinion , the dimming is a plus so all we are left with is the fitting / removal and cost. If selling the car can the aftershock be removed and the original equipment reinstalled? 2015 4.4 AB
26th May 2020 10:27pm |
Yes, you can easily switch back to OEM if you wanted to for whatever reason...but I highly doubt anyone would want to go back to the OEM setup after having the Android unit installed.
26th May 2020 10:37pm |
