![]() | Home > Maintenance & Mods (L322) > Sill repair/fabrication in beds/herts/essex ? |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 ![]() ![]() ![]() |
On the underside of the block is a pin, pull this out and then just pull the block from the sill. |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 544 ![]() ![]() ![]() |
Slight thread hijack - BMW most certainly didn't sort the rust problem out on the E46, you're just very lucky. The front wings rot on the wheel arch where the inner plastic splash guard rubs, the sills rot out and the rear wheel arches are even worse than the L322. THe E36 has proven much better in this respect (although no paragon of virtue!). Oh, and the more powerful versions the rear subframe carriers can split (badly), particular issue with the M3. Back on topic, L322 seem extremely variable in sill rot issues. It was one of my main criteria when buying the two we're liucky enough to have. both 2010 cars with minor surface rust on the arch and no rot in the sills at all (had the plastic covers off to check). Remedial work underatken to remove all rust and wax seal with edge protectors fitted (like LR should have done). Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 ![]() ![]() ![]() |
Interesting, I viewed a couple E46's before this one and they did have the rust on the wheel arches (forgot about that) But I put that down to poor paint care.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Excellent news on the Ronnie Jnr (YRM) front....! If they can manufacture sill and arch repair panels that will be amazing. I've watched their range grow enormously over the the years to provide solutions to lots of LR issues.
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 54 ![]() ![]() |
I'd be really interested in these as well looking forward to update soon |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 857 ![]() ![]() ![]() |
it will definately be a major issue sorted out for all us early L322 owners, if Ronnie and mazza can get these parts produced and stocked in a UK warehouse, fantastic news really ! |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
Me too, given my car lives in the, often very wet, west of Scotland. |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Well, you could put me down for two pairs of wheelarches (& maybe sills too)). 1 set for now & a spare set for a later L322 when I replace this one in the future. 2003 Range Rover Vogue TD6 |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
I'll be up for a pair, if they get manufactured. |
Thanks for this, ill be using this picture to send to Ronnie as ill be needing something to reference haha, the sills cut out today (pics to follow) |
Well, the vehicle has gone in to have the lower sills removed today. They left behind some of the foreign material as some of it can be cleaned up and re used its salvageable (not much mind)
Who’s doing it for you?
Dr Rob you know there off to YRM
I do hope Ronnie Junior comes to the rescue, the odds are that most L322's in the UK are going this way |
